alternator pulley replaced - SR20 Forum
Old 10-04-2002, 11:42 AM   #1 (permalink)
the other day when i was cleaning my engine, i noticed that the alternator belt was bad, but i had them just replaced. when i looked to see what was causing it, i found out that my alternator pulley was dented in and causing the pulley to tear up the belt. i don't want to replace the whole alternator, has anyone just replaced the pulley. is it hard to do, do i need a impact gun to remove it. any advice in how to remove the pulley would help. sorry the thread is so long for a simple problem.
nxgoody2000 is offline   Reply With Quote
Old 10-04-2002, 12:07 PM   #2 (permalink)
Get a UR pulley.
93 NX2000-7.75@92mph 5SPD SWAP, 2120lbs. JDM Motor, Calumsult Realtime ECU, BC3 cams/gears, CP XTP 9.2:1 pistons, NX DP-100 shot, 333's, N60, Prothane Mounts, ACT Xtreme/sprung 6 puck, Fidanza, PR WAI with JWT POP, 2.5" SSAC, Dynomax 3" muffler, Outlaw Intake Spacers, OEM wires, ngk plugs, UR Pulleys, Walbro 190, ST springs with KYB's, Kinetik KR912, Axis maglites
Old 10-04-2002, 02:30 PM   #3 (permalink)
AaroNX, i'm talking about removing the pulley. i know UR makes one for it. I'm asking how i would take out the pulley. i know there is a nut holding it on. Can i just unscrew it with a socket or do i need to hold the pulley still and use a impact gun to take it out.
Old 10-04-2002, 03:46 PM   #4 (permalink)
i think from the info off naji's website he said the best method was to use an impact wrench
http://home.earthlink.net/~eliterit/images/fccf4ff1.jpg
eliterit
93' SE-R I/H/E 19*
90' 240sx (dohc)
eliterit is offline   Reply With Quote
Old 10-05-2002, 05:17 PM   #5 (permalink)
Shift_UK SR20
solution
hey man i work at advance auto parts and they have an impact wernch in store that u can use and if u don;t want to spend the money goto a junk yard and get a bad alter for 5 - bucks and u will be straight auto zone also has the impact wernchs
94 Sentra SE-R Auto - Bringing it back from the dead!!
w11det, garret/air research t3/t4, Log manifold, Turbonetic's W/G, Turbo XS RFL BOV, z32 Maf, Apexi SAFC2, STI 520 injectors, Mallory 635, Mallory pro fire coil, Precision FMIC
96 200sx Se-R "B14 Monster" - Sold
93 Sentra Se-R "1SLO SER" - KIA
akes200ser is offline   Reply With Quote
