Crank sensor P0335 code - SR20 Forum
Old 12-17-2010, 08:34 PM   #1 (permalink)
Trying to go FASTER!!!!
Hey guys,
I bought a fidanza flywheel part number 143621 for my b15 trany swap. And the code still showed up. I replaced the sensor and the code is still there. This sucks. Has this happened to anyone else? I also have a P0115 code my coolent temp sensor which i replaced also. I have no idea. I checked for undone plugs and dident find any.
Thanks,
Tim
timg20t is offline   Reply With Quote
Old 12-18-2010, 07:54 AM   #2 (permalink)
eric96ser's Avatar
Feedback Score: 29 reviews
http://www.g20.net/forum/showthread.php?t=74686
Conflicting info in this thread.
The community is here.
Old 12-18-2010, 08:51 AM   #3 (permalink)
Hey thanks for the info. ill read it but i asked alot of people and they all said i needed the 143621 flywheel. which i got. and im still showing that damn code.
Old 12-19-2010, 09:14 AM   #4 (permalink)
ok so this is what my issue is. After i swaped in my new B15 trany i have two codes. The P0115 and the P0335 its my temp sensor and the crank sensor. I replaced my temp sensor with a new one and i still have that code. I bought a new findanza flywheel. I did a ton of research so i got the right part number for the crank sensor to work right. My mechanic said that since the codes show up right away once the car is started its a hard fault. Which he said means that something is not connected right or they are grounding out. Could the two codes be related? Can someone please help me out?
Thanks,
Tim
Old 12-19-2010, 10:53 AM   #5 (permalink)
Bump. It would be nice to drive my car. I miss it.
