NX2k wont start - SR20 Forum
Old 01-08-2011, 05:51 PM   #1 (permalink)
NX2k wont start
like title states my nx2k wont start i have fuel and spark both confirmed .....not sure if injectors are firing *** it run when starter fluid is used .....plz help ppl need the car on the road
srb13 is offline   Reply With Quote
Old 01-08-2011, 06:18 PM   #2 (permalink)
motor ran fine before auto to manual swap now it wont start
Old 01-08-2011, 06:33 PM   #3 (permalink)
its stock ;)
Feedback Score: 53 reviews
if it run on starter fluid it isint getting fuel into the cyl.
crank position sensor maybe?
have you pulled a spark plug out to see if they are wet?
race car:
1997 200sx se-r - t28 in the works
winter beater:
1995 200sx se-r- crashed then sold
1990 Subaru Legacy- you know you want one
byronchrisp05 is offline   Reply With Quote
Old 01-08-2011, 06:39 PM   #4 (permalink)
Feedback Score: 55 reviews
fuel pump?
93 sentra xe dd (gas saver)
91 sentra se-r project car
97 200sx se-r new baby [/U]
99 sel
93 se -r
99sel-r is offline   Reply With Quote
Old 01-08-2011, 09:05 PM   #5 (permalink)
fuel pump primes .......what would could be not allowing the injectors not to fire i swapped ecu between already to
Old 01-08-2011, 09:06 PM   #6 (permalink)
plugs were dry where is crank position sensor
Old 01-09-2011, 10:23 PM   #7 (permalink)
i found out *** it was ...the send line from the fuel tank was cracked
