b 15 tranny - SR20 Forum
Old 01-14-2011, 09:00 PM   #1 (permalink)
big boost
b 15 tranny
whats up guys i swapped my b13 tranny for a b15 but i have a problem the driver side axel does not seem like it fits properly can anyone share some knowledge on what i should do
Turboser is offline   Reply With Quote
Old 01-14-2011, 11:14 PM   #2 (permalink)
On the drivers side axle there is a c-clip on the end of the axle that goes in the transmission that you have to pop into place hope this helps
01_sentra2.0 is offline   Reply With Quote
Old 01-17-2011, 11:28 PM   #3 (permalink)
big boost
okay i will check that out
Old 01-18-2011, 03:07 AM   #4 (permalink)
Feedback Score: 13 reviews
If you have the correct axle, which you should.
This is one of those things you learn to deal with.
Myself, after doing them a hundred times.
Push the axle in as far as you can get it by hand, thread the axle nut onto the end.
Grab a FU*Kin HUGE hammer, and whack it. Should take one or two hits but just bash it in.
Done.
GL,
Dudeman
