Help! Fried ECU? - SR20 Forum
Old 01-23-2011, 01:28 AM   #1 (permalink)
Knuckle buster
Help! Fried ECU?
While fixing a coolant leak, I removed the distributor and accidentally pulled the 4 ECU wires out of the dizzy side of the plug.
I tried to put them back into the correct pins, and shorted something out
A 25 amp ENGINE CONT fuse got blown, but all others were OK.
Replaced the fuse and got a replacement dizzy harness from the junk yard.
Still, the engine won't start. There is no spark, and I can't hear the fuel pump. Testing the ECU for codes gives no flashing lights whatsoever.
Did I fry the ECU? Any other suggestions
Thanks
clintavo is offline   Reply With Quote
Old 01-23-2011, 10:00 AM   #2 (permalink)
TunerCode
More than likely. Take the covers off the ECU and see if it looks or smells burnt.
Dave
dfddfd2 is offline   Reply With Quote
Old 01-23-2011, 01:36 PM   #3 (permalink)
Knuckle buster
Everything *looks* normal under the cover.
