SR20DET Fire up hesitation! - SR20 Forum
Old 01-25-2011, 11:25 AM   #1 (permalink)
I have an occuring problem since i bought my sr20 and i would like it solved due to its annoyance =/
When i crank the car it take about 10 seconds for the car to actually fire up (when the car is cooled down) If the car is already warm then it fires up no problem. My guess is ultimately Fuel Delivery?? to troubleshoot..i have installed the following parts
-Nismo AFPR
-Walboro 255
-Spark Plug Replacement
-Z32 Fuel Filter
Yesterday while looking in the bay..i noticed that the Main Engine harness was in poor condition with exposed wires and such. Could this be a faulty engine harness problem not sending enough fuel to the rail? Obviously the harness is a bit pricey and dont want to buy more parts than i need to.
Any ideas or opinions will be highly appreciated!
-Darren
Dkouki97 is offline   Reply With Quote
Old 01-25-2011, 11:43 AM   #2 (permalink)
i have the same problem i think its just a sr20 thing as mine cranks for like 5 seconds then fires but runs on 2 or 3 then 4 cylinders or until you give it gas
gen_max_pain is offline   Reply With Quote
Old 01-25-2011, 12:13 PM   #3 (permalink)
Well im sure it can be fixed. Cause 10 seconds to fire up is definitely not normal. All my friends SR's start up no problem
Old 01-25-2011, 02:41 PM   #4 (permalink)
SE-R Oldie
Feedback Score: 5 reviews
you installed those parts and still having the issue? maybe replace your spark plug wires as well.
'93 SE-R 16x,xxx e
BoggeN is offline   Reply With Quote
Old 01-25-2011, 04:46 PM   #5 (permalink)
Well you think that's a possibility cause the car starts up sometimes fine when I prime the fuel pump by turning the key to the on position and waiting 3 seconds
Old 04-22-2011, 06:20 PM   #6 (permalink)
lil josh
did anyone figure anything out about this?? im having the same problem with my b14 ser
98nismosx is offline   Reply With Quote
Old 04-22-2011, 11:05 PM   #7 (permalink)
92 Sentra SE-R
How about the fuel lines or a fuel line, being clogged up?? Does anyone know the answer to these gentlemens question?
NissanUnlimited is offline   Reply With Quote
Old 04-23-2011, 02:48 AM   #8 (permalink)
mines has the same problem...i was told it was the fuel filter..ill try it this weekend
rodneyfromtrini is offline   Reply With Quote
Old 04-23-2011, 11:00 PM   #9 (permalink)
lil josh
i would assume mine could probly use it. ill pick one up tom after easter breakfast with the kids and ill let you know how it turns out
