in the middle of of a SWAP - SR20 Forum
Old 01-27-2011, 11:24 PM   #1 (permalink)
b13 R.T.S
I'm trying to swap my 91 4door xe (automatic)!!
So far I got :
96 sr20de auto from a g20
A se-r tranny
a se-r harness
A se-r ECU
A light weight flywheel
A Clutch
Se-r motor mounts
Can anyone else tell me what I'm missing !!??
DaCKsoNeR-B13 is offline   Reply With Quote
Old 01-28-2011, 12:34 AM   #2 (permalink)
Nitelife's Avatar
Feedback Score: 46 reviews
Read up here
Old 01-28-2011, 01:06 AM   #3 (permalink)
gifted at FAIL
Originally Posted by DaCKsoNeR-B13 View Post
I no a couple of things that r missing but I want ta make sure I have everything be4 the swap it my daily driver!!
before you "no" a couple of things. first you must learn how to spell KNOW. along with the rest of the painful text language you speak....
si-r_to_se-r is offline   Reply With Quote
Old 02-18-2011, 03:05 AM   #4 (permalink)
b13 R.T.S
If your not gonna help y you bother on posting
Old 02-18-2011, 03:07 AM   #5 (permalink)
b13 R.T.S
My problem is that I'm putting in a low port and I want to know what I need to make it run on the b13
Old 02-27-2011, 12:27 AM   #6 (permalink)
b13 R.T.S
Bump
Old 03-02-2011, 08:13 PM   #7 (permalink)
b13 R.T.S
Bump
Old 03-02-2011, 08:36 PM   #8 (permalink)
B13 Fan
Feedback Score: 12 reviews
same as any other GA to SR swap the correct ECU and harness.
94sentraxe is offline   Reply With Quote
Old 03-03-2011, 12:18 AM   #9 (permalink)
b13 R.T.S
But my motor is a lowport not a highport ! A homie said I have to change some sensors?
Old 03-03-2011, 05:17 AM   #10 (permalink)
B13 Fan
If your starting with a GA anyway you have to start from scratch. You can use the lowport no problem because you haven't had a highport. when you swap GA to SR you have to replace almost everything from the engine, tranny, axles, mounts, etc. to the computer and harness. As long as you stick to parts from one or the other you're fine
Old 03-03-2011, 12:11 PM   #11 (permalink)
SR20's since '97
Feedback Score: 24 reviews
Dack, Just search the forum as others have said all the info is out there. If your GA High/Low port is irrelevant.
If low port and not a 94 you will need OBD1 Stuff like ECU / Distributor.
A little spelling will go a long way, If you come off like writing stuff all outta wack they are not going to take you seriously.
Good luck with your swap.
Daryl G. - SR20's since 97
06 G35 6MT Sedan
92 Sentra SE-R DET
- DET Build Thread
98 Sentra SE ( RIP ) 14.2 NA
89 325is ( sold )
94 Sentra SE-R ( sold )
90 CRX SI w/GSR + bolt ons ( sold ) 12sec all motor
00 Jetta GLX VR6 ( sold )
QUiKSR20 is offline   Reply With Quote
Old 03-25-2011, 04:12 PM   #12 (permalink)
b13 R.T.S
Bump
