not turning over - SR20 Forum
Old 02-19-2011, 11:03 PM   #1 (permalink)
wantin another se-r!
not turning over
k...got a 98 b14 ser and *** put in a 01 rr sr20de....everything is in connected and ready to go...BUT im not able to get the car to turn over...tried everything...but i get nothing when i turn the key...i was able to jump the starter and got it to turn over...any ideas? also will the security built into the ecu be an issue? im not worried about keyless entry or anything so does it matter if it has security or not? i also have used the 98 manifold on it.... and one more thing id like to know is if the 98 work with it? im kinda new to the whole RR thing so yeah....i prolly look like a jackass with some of these questions lol so please anybody HELP!!!
shift denied!
1996 200sx se-r vvl'd world rally blue
200sxsermatt is offline   Reply With Quote
Old 02-23-2011, 02:45 PM   #2 (permalink)
anyone?
Old 02-23-2011, 04:33 PM   #3 (permalink)
I would say in order for people to help you, you are going to need to be a little more specific regarding how you did your swap. I am going to assume you used the RR longblock and swapped all the b14 parts over including the manifold, distributor, sensors, etc... so therefore you are using your original wiring harness and ecu?
If that's the case, you might have overlooking wiring something up on the swap. When you turn the ignition key to on (not starting the car) the ECU should show the check engine light as on, this means the ECU is ready for the car to start. If it doesn't do that, you need to check your wiring and fuses. If the light is on before you are starting and you go to turn the key one more step to stage the starter, you should hear the starter trying to turn the motor over. I know you said you tried to jump it and it worked (so I'm assuming you used a direct power source to turn the starter). It might be something as easy as having your wiring mismatched for the starter?
So for someone to help you, obviously you can see that there is a lot of guessing involved. Take it step by step, explain what you did for the swap (different ECU, different than orgininal harness?) all of those things are huge factors into getting your car running again. I hope some of this insight helps.
ferrari21 is offline   Reply With Quote
Old 07-16-2011, 09:38 PM   #4 (permalink)
i have a simular issue but all i did was replaced the clutch, it did this intermintantly before so i have replaced the clutch sensor and have traced all the wires but it still does not start consistantly. any ideas?
jstole1 is offline   Reply With Quote
