Originally Posted by Nyc Sr20PowerD
what are your reasons for doing this? just curious?
because i have a b14 with b13 ecu via jumper harness and when i went to dyno my car , the tuner said it wasnt able to be tuned because the timing was jumping everywhere. We checked everything and i knew everything was in working condition, because when it was all motor with the jumper harness it was running good and when i put it on boost with it needed tuning so hence the dyno tune, but nothing else could possibly cause the timing to jump like that said the tuner and suggested that i use a b13 dizzy in order for the ecu to read the correct signals from the obd1 dizzy. It kinda makes sense and well the car runs straight but i dont want to spend money on dyno and tune that didnt work so thats why im investigating to see if this could be the issue.
