b14 hard to start and runs poorly - SR20 Forum
Old 03-10-2011, 09:55 PM   #1 (permalink)
Hey I have been having issues with my B14 ok so the first thing that I noticed was that if you revved from idle so like 800-1000rpm it would spit and sputter and miss until it reached about 1500-2000rpm then after that it was fine. So now if it is cold it takes a good 5-10 min to get the car running and it is still hard to start from idle and at WOT it cuts out it will rev then just sit without revving for a little bit start revving again then cut out it is getting really annoying and I was wondering if any of y'all had any advice. So far I have tried 2 ECUs, 2 MAF sensors, 2 fuel pumps, changed the spark plugs, fuel filter, and spark plug wires, tested the fuel pressure, ran the check engine light the codes that I get are P1401,P0335,P0705,P0170
se-r200sx is offline   Reply With Quote
Old 03-11-2011, 10:17 PM   #2 (permalink)
Checked the injectors today and they are all firing fine with a good fog could it be the distributer?
Old 03-15-2011, 01:08 AM   #3 (permalink)
Hey I replaced the distributor yesterday and the thing is working great now this is my 4th distributor on the car so yeah if you are ever thinking of getting a distributor from advance auto don't just find a used one somewhere
