Clutch problems - SR20 Forum
Old 04-02-2011, 12:35 PM   #1 (permalink)
ian
Don't call it a comeback
Feedback Score: 3 reviews
Clutch problems
Okay, so I just put a 43K trans into my SER with a new B15 DISC Stock PP and new TOB. I am hearing a strange noise when the clutch is let out, almost like a sort of warble or varied-pitch whine. Hard to describe. Definitely sounds friction-related. It does it in nuetral with the clutch out and when moving with the clutch out. The car also doesn't like to go back into first gear. The pedal is engaging high (quickly) even though I have given the cable all the slack it has. WTF!?? Ive put a couple transes in before and a clutch once before, and never had these issues.
96 DSP SER: SOLD! Bye baby!
03 Sentra SE-R Spec V GStock Eibach Sway, Kumho 710's, K&N, Koni Yellows
1991 NX2K! Road Magnets, 15x8 15mm XXR 501's with OG Azenis RT215, JGY (Eeeew) exhaust, WR WAI and $tealin FSTB RUST FREE!!!!
ian is offline   Reply With Quote
Old 04-05-2011, 04:26 AM   #2 (permalink)
Wants Primera Race Motor
Sounds like possibly the input shaft bearing
Brian
95 Black 200sx SE-R(totaled)
97 Teal 200sx SE-R(Sold)
12.5@ 114 boosted
295 whp 298 tq (street tuned)
303 whp 301 tq (dyno tuned)
01 Black G20t
04 GSXR 600
BlkB14 is offline   Reply With Quote
Old 04-05-2011, 07:53 AM   #3 (permalink)
ian
where exactly is that?
Old 04-05-2011, 06:56 PM   #4 (permalink)
^^ if you havent googled it by now.
Its along the input shaft, Inside the trans.
Old 07-24-2011, 09:24 PM   #5 (permalink)
SE-R GAWD
idk if i need to replace my clutch cable, hopefully someone nice enough can help me with my problem. i replaced the whole clutch assembly a month ago maybe earlier. my car ran good to the beach and back until i was a few blocks away from home. the pedal wasnt feelin as stiff as be4 and at 1 point it stuck to the ground. i cant go into 1st. i checked the cable by the trans and it felt kind of loose but when i tried to tighten the cable, the nut was tight but the cable had some play still. if **** has an idea and can help me out in anywaay, i'd apreciate it. thanks -johnny
MARSHMELLOWSE-R is offline   Reply With Quote
Old 07-25-2011, 08:31 PM   #6 (permalink)
Boost is like Crack
i never re-use pressure plates for that reason... If its not going into gear with the clutch pushed its not releasing to slow the imput shaft down. if u have checked the cable adjustment its the plate or the t.o.b isnt installed right.
Bred407 is offline   Reply With Quote
