Engine won't start - SR20 Forum
Old 04-20-2011, 03:51 AM   #1 (permalink)
Engine won't start
I have a U13 bluebird with an SR20 that won't start.
It is sparking, and getting fuel through the injectors, it has good compression.
The engine fires for like a second when first cranked, then it dies.
Giving it throttle makes it even worse.
It seems like it may not be getting enough fuel?
The fuel pump has been replaced and is working fine.
Does anybody have any solutions?
Cheers,
Chris
N/A-SR20VE NUT! is offline   Reply With Quote
Old 04-20-2011, 10:00 AM   #2 (permalink)
SR20 Newbie
Its must be your ignition system.You said you replaced the fuel pump right & it cranks right but wont start.From my point of view,you might have a bad starter or dead battery.Check for those options.
Chills327 is offline   Reply With Quote
Old 04-20-2011, 12:22 PM   #3 (permalink)
i had the same problem. pull the relay for the fuel pump and try to start it again. if it starts then it is probably a bad o ring on an injector or fuel pressure regulator, causing it to flood. good luck!
dextersdarkside is offline   Reply With Quote
