Looking for some tranny knowledge, looking for B15 spec v tranny swap knowledge, I have an 03 pontiac vibe GT ie 2zz with celica gts sourced 6speed and an 04 mr2 spyder that the 2zz is destined for. Both are daily driven by me and my girlfriend out here in Port Jefferson Long Island NY
Both cars are soon to need clutches so brain started turning on transmission clutch flywheel mods, from previous nissans and my bros gts I became aware of the shared mfa60 aichi 6speed trans toy nis hyn mzda etc soooo in search of lower gearing and lsd I am buying an 04 spec v tranny and am plotting out a swap into my vibe followed by the whole drivetrain swap to mr2... need money to rebuild and fortify motor ** swap as the vibe has 200k now (work at a shop got it for peanuts 2 years ago as a 2zz piggybank and daily hauler)
Anyway im picking up the tranny this week and need to start getting finances prepared parts ordered and planning for downtime so I need tranny knowledge from you well educated SR20ites as the vibe community is more concerned with subs and rims than swaps and ratios
Main concerns:
clutch and flywheel options spec v has bigger clutch spline and disc diameter
I believe my trans has a 215mm clutch similar to sr size but idk what flywheel I would need to use 225 240 or 250mm options I am seeing discussed
Axles the same?
sensors?
Shifter setup?
Any input or info from anyone who has used the celica gts tranny for a 6speed swap
Basing most info off this thread:
http://www.sr20forum.com/driveline-t...-your-car.html
more info:
http://www.sr20forum.com/driveline-t...3-b14-p10.html
ratios:
6 Speed transaxle Ratios:
02 Spec V = 3.417 / 1.944 / 1.258 / .947 / .773 / .630 Final drive ratio 4.43
late 03+ Spec V = 3.153 / 1.944 / 1.392 / 1.055 / .809 / .673 Final drive ratio 4.133
+LSD in both of course
Celica GTS Vibe GT - 2ZZ C60
1st / 2nd / 3rd / 4th / 5th / 6th / Rev / Final
3.166 / 2.050 / 1.481 / 1.166 / 0.916 / 0.725 / 3.250 / 4.529
C63: Toyota MR2 Roadster/Spyder 2003-2007 Toyota Celica (Uk/ Europe)
http://www.theperformancedivision.co...roducts_id=284
3.166 / 1.904 / 1.310 / 1.031 / 0.864 / 0.725 / 3.250 / 3.941
also just for info sake:
Tiberon = 3.153 / 1.944 / 1.333 / 1.055 / .857 / .704 Final drive ratio 4.43
Maxima = 3.153 / 1.944 / 1.392 / 1.055 / .809 / .630 Final drive ratio 3.812
Celica GTS = 3.166 / 2.050 / 1.481 / 1.166 / .916 / .725 Final drive ratio 4.529 (same as Vibe GT/ Corolla-Matrix XRS)
heres a pic of the euro mr2 6speed w/ lsd (c63)
Thank you in advance;
And hello again
Cheers
Michael
