Originally Posted by bimmermanic
All i need to know is if the distributor can be replaced, relocated or removed with a Nissan Spec. Distributor less system
You can replace the distributor with a 20V/VET cam angle sensor to give you a little bit of room. Then install 20V/VET coil-on-plug (and valve cover) and an appropriate engine management system and you'll be in business.
However, you'll still have to make an adapter to bolt a RWD transmission to the FWD block.
It is MUCH MUCH MUCH easier to just start with a RWD block to begin with. Why is that not an option for you?
