not the usual idle suspects
Okay, so i've been through the usual idle issue and stumbling issue threads and flowcharts.
My issues are rough idle (sounds like big cams, 282s or bigger), excessive fuel consumption and lack of powerband.
Driving the car, when cold, starts up just fine no hesitation or long cranking to start. Until it reaches operating temp it misses and studders, hesitated and backfires. Once the car reaches operating temp, it drives fine, just low on power and has a very speratic powerband, 2-3.5k its fine, dips off till 5k then opens up for 500rpm then drop hard until 7k. The idle jumps from 500 to 1k and sounds like it has huge cams, as previously stated.
So far I have done these things to try to fix, from the best of my memory not strict to this order:
Emissions delete
Resealed intake manifold with helicoil on all bolts
AAIC removal
Cleaned out IAC
Recleaned IAC
Replaced o2 sensor
Replaced o2 sensor again with skinny o2 sensor
Put on ebay WAI
replaced maf
replaced knock sensor
Compression test 190,190,165,190
replaced fuel injectors with a used KAde set
installed fuel pressure gauge (forgot what im getting but its FSM normal)
regrounded maf
tested TPS checked out ok
replaced coolant temp sensor
replaced pcv valve and hose
fixed crack in intake manifold where egr bolts to
complete tune up
basically im stumped, im basically down to thinking either a bum ECU or another leaky fuel injector. I pulled the ecu and took a look to see if it had the DSM common signs of being bad, since thats what community i was previously with. Ecu and boards looked immaculate and didnt smell burnt at all. As far as im aware of this is the original ecu. When i got the car it idled and drove fine. Then about 3 days after i bought it i lost 5th gear and it started loping on the idle and its been a battle to fix the lope for about 6 months now.
Any experts got advice? The wife said i cant turbo it untill it runs right, and well, im itching for boost.
