Just finished my s14 sr20de/vct swap into my s13, I used my KA loom and ka24de ecu to run the sr. started fine, runs good in the high rpm range. slow in the low rpm range and putters at about 3 to 4 rpm but pulls after that. When i shift gears the rpm's slowly climb down befor any pick up...
My question is can the s13 sr20de ecu run it better than the ka im not worried about the vct, I can get a msd switch to run it, or will i have to get my ecu tuned for this motor???, or will the s14 sr20de ecu work on the s13 loom im using??
thanks for your help
