B14 GA16 to SR20 swap question - SR20 Forum
Old 06-29-2011, 02:13 PM   #1 (permalink)
So I am just about done with my swap I went from GA16/5-spd to SR20DE/5-spd engine all hooked up and mounted problem is when I went to crank the engine it turns but does not get fuel. Now I do not want to splice a whole bunch of wires as I bought 2 new harnesses for the engine Do I need to replace the underdash harness to make this work? if not what am I not doing correctly?
sandrider123 is offline   Reply With Quote
Old 07-11-2011, 04:53 PM   #2 (permalink)
Nismonster
Did you check too see if your fuel lines are connected properly?
DaveM is offline   Reply With Quote
