b13 transmission questions - SR20 Forum
Old 06-29-2011, 06:37 PM   #1 (permalink)
hi everyone,
just started my b13 project car and i have some questions about the se-r 5 spd tranny. In order to run approx. 300-320 horses what parts and modifications are normally done to the tranny on the b13?
I have already purchased a ACT clutch kit and fidanza flywheel. as well as a 5th gear popout fix kit.
To run the hp i am looking for do i require a new gear set or shot peening or/and cryo treatment?
jester2358 is offline   Reply With Quote
Old 06-29-2011, 08:39 PM   #2 (permalink)
going thru life @ 1 bar
Feedback Score: 21 reviews
The best idea is to usually buy a B15 trans. But there are some guys that are able to keep the b13 trans and make it last at that power level.
Thick gear oil is a must.
...Currently down due to a clutch disc spring failure....
Old 06-30-2011, 03:53 PM   #3 (permalink)
thanks for the info but didnt really answer question, are new gear set and trans treatments required for running 300-320 horses.
Old 07-13-2011, 10:16 AM   #4 (permalink)
hey jester u said u purchased a 5th gear popout fix kit... where did u purchase tht from and how much it cost?...i have the same problem with my b13 ser...the 5 gear wont stay engaged and keeps poppin out ...im trying to find out y and a solution for it.....can u help?
ser_mel is offline   Reply With Quote
