hesitation and sputter when very light throttle - SR20 Forum
Old 06-30-2011, 09:42 PM   #1 (permalink)
ian
Don't call it a comeback
Feedback Score: 3 reviews
91 NX2K Has a sputter in any gear under very light acceleration or speed maintenance. Goes away when given more throttle input Any ideas guys?
96 DSP SER: SOLD! Bye baby!
03 Sentra SE-R Spec V GStock Eibach Sway, Kumho 710's, K&N, Koni Yellows
1991 NX2K! Road Magnets, 15x8 15mm XXR 501's with OG Azenis RT215, JGY (Eeeew) exhaust, WR WAI and $tealin FSTB RUST FREE!!!!
ian is offline   Reply With Quote
Old 07-07-2011, 04:09 AM   #2 (permalink)
SR20DE fan
Is it the same regardless if the car is cold or warm? If yes I would say it it the TPS - the best way to diagnose this is hooking the car on computer, and checking the TPS values, if it is not linear but jumping up and down when as you step slightly on the throttle, the TPS is bad and needs to be cleaned or even replaced.
kajencik is offline   Reply With Quote
