SR20DE engine swap into something smaller - SR20 Forum
Old 07-09-2011, 03:46 PM   #1 (permalink)
JFV
Hi folks was wondering if anyone could shed any light on this situation.
I have a p10eGT running 180hp but is a bit rotten and sadly falling apart, so I'm thinking about an engine swap into a smaller nissan something that won't cost so much to do though. I was thinking about a swap into a 1.4 n15 or a 1.5 n16 as these are quite cheap and usually less rotten than the sport/ gti spec that I've seen. will it fit in with little to no major work considering I will have a whole p10 to take parts from. Any ideas or anyone done a swap please help. Thanks
JFV is offline   Reply With Quote
Old 07-11-2011, 05:28 PM   #2 (permalink)
Nissan Sunny N14 GTI
why not a P11 of G20? These are mutch better (less rusty) than the n15 and n16 Nissans. You can also use the P10 shafts. And purhaps swap the whole wiring.
Mark N14 SR20DE is offline   Reply With Quote
