Popping noise while braking hard - SR20 Forum
Old 07-10-2011, 01:21 PM   #1 (permalink)
I just recently upgraded my brakes to nx2000 and put new rims. While driving, I don't hear any noise. But when I brake hard, I hear a loud popping noise coming from the driver side and passenger side. Can someone help me out?
Black_b13 is offline   Reply With Quote
Old 07-10-2011, 02:15 PM   #2 (permalink)
That sounds like a strange one. Here are my initial thoughts....
Do you have ABS? If so, you may want want to investigate that system further.
You may also look over your suspension to make sure everything is working order and torqued down. Tie-rods, balls joints, sway bars, ect.
If you upgraded to slotted or cross-drilled rotors, you may notice they make a different noise when braking than solid rotors. It would be something to check, but I doubt it.
DrunkenMonkey is offline   Reply With Quote
Old 07-10-2011, 02:27 PM   #3 (permalink)
I don't have ABS. And I am going to change out my lower ball joints and wheel bearings soon. I'll see if that makes a difference
