replacing power steering hose, which way for the valve/spring
Hey there, I can be such an idiot... I pulled the high pressure hose off the power steering pump (it sprang a leak), and the valve and spring fell out and I didn't notice what order..... do I put the spring back in first and then push the valve in screen side first so the flat end is facing out the hole? Does this make sense? Any help is greatly appreciated! DannyHey there, I can be such an idiot... I pulled the high pressure hose off the power steering pump (it sprang a leak), and the valve and spring fell out and I didn't notice what order..... do I put the spring back in first and then push the valve in screen side first so the flat end is facing out the hole? Does this make sense? Any help is greatly appreciated! Danny
out there somewhere
