help ignition problem weird!!!
hi ill start off by telloing you my turbo got to much oil pressure and blew,replaced turbo and added a restrictor,now car sounds like its running on 3 cylinders. i have cleaned out all piping,intercooler,and new spark plugs. still no change.i looked at my firing order and it was all screwed up but never touched it car ran fine before. changed plugs to the 1.3.4.2 like its supposed to be and now wont start. its an sr20gtir,fully built in a 91 se-r.car does not chatter or knock, smokes alittle now im guessing its from the oil dumping in the exhaust and inter cooler. also when it was running pull spark plug 1 wire and no drop keeps running the same..... hope some one has an answer thanks
