Vacuum tubes - custom build - SR20 Forum
Old 08-15-2011, 07:25 PM   #1 (permalink)
FINALLY finishing my Deman SR7 kit car with S13 ( essentially an engine with 4 wheels and 2 seats) , vacuum lines one of the few items to do .
There is no EGR, recirc valve or carbon cannister.
My engine came with a hose from the lower throttle body to the LH port on the intake just above the throttle body. Assume this is correct ...welcome input.
Thinking that I can then route ...
- one hose from the fuel pressure regulator to the larger port on the intake above the throttle body
- the turbo side is straightforward (once I can track down a wastegate control valve) but from the T attached to the intake after the MAF, should this go anywhere?
gllongdrink is offline   Reply With Quote
Old 09-15-2011, 05:34 AM   #2 (permalink)
OK, no info from the forum ... so here is the answer FYI
One vacuum hose from the pre-throttle body intake to the wastegate with a manual boost controller inbetween the two .... and one hose from the fuel injector regulator to the intake manifold port.... simple!
