Sr20 fwd and rwd gaskets... - SR20 Forum
Old 08-23-2011, 06:41 AM   #1 (permalink)
Hey guys I'm from australia and I need a full gasket or vrs kit for a rwd s13 silvia sr20de.
I wanted to know if the fwd head gasket/intake/exhaust and others were the same as everything is significantly cheaper in the us than here.
It would be great if you guys could shed some light on this for me.
JDM AUS SILVIA is offline   Reply With Quote
Old 08-23-2011, 05:08 PM   #2 (permalink)
S12 NUT
Exhaust gasket is the same, maybe the intake to head might be the same too (depending on high/low port).
Otherwise, there aren't really that many gaskets on the SR, it's all more or less RTV.
Only gaskets are really the two intake, exhaust, IACV, throttle body, valve cover, and head.
When I did my rebuild, I just made my own for everything but the head gasket (for obvious reasons).
1987 Nissan 200SX/Silvia (S12) Specs:
  • SR20DE+T (94 S14, VCT)
  • 9.5:1 Compression (Sentra pistons)
  • T25 @ 11PSI
  • 450CC DeatschWerks Injectors @ 60PSI (528CC/min)
  • Bosch 023 Fuel Pump
  • MegaSquirt Extra 029y4
  • Custom FMIC
  • Currently maxing out injectors!
seishuku is offline   Reply With Quote
Old 08-23-2011, 11:07 PM   #3 (permalink)
Thanks for that, yeah doesnt look like its possible for the head. I still get one of those kits as they have most of the other gaskets, I might go make a head gasket to compensate.
Who's going to Matsuri?
