Relays getting power but not engaging - SR20 Forum
Old 08-26-2011, 01:47 AM   #1 (permalink)
I am having an issue with the relay rack that holds the EGI relays on it not engaging. When I test them I am getting ignition power to pin 2, but no ground on pin 1. Should pin 1 be seeing ground? It seems that way when I look at the schematic. I am also not getting continuity between any of the pin 1's in that relay rack, so it has me wondering what is up and how they are supposed to see ground.
Audio Engineering School
Radkins is offline   Reply With Quote
