MSD 2 Step problems. - SR20 Forum
Old 09-02-2011, 12:36 PM   #1 (permalink)
Faster then stock...
Feedback Score: 3 reviews
Alright, have searched but not coming up with the same problem that I am having. Got the 6al installed and the 2 step module that goes with it. Part numbers; 6425 on the msd box has a 100 rpm increment in rev limiter, and 8732 on the 2 step module... On to the problem.
I set the rpm at 2000 rpm on the 2 step and it cuts out at 4000 rpms. It doubles whatever I set it at. All wiring is tight and grounds are good.
Thanks for any insight.
This is in a 91 b13 with jwt ecu and u13 engine btw...
98% of teenagers do or has tried smoking pot. If you're one of the 2% who hasn't, copy & paste this into your sig.
Iroc_92 is offline   Reply With Quote
Old 09-03-2011, 03:33 AM   #2 (permalink)
Sounds like its setup for the wrong number of cylinders ?
http://www.msdignition.com/uploadedF...ions1/6425.pdf
Page 5 details cutting wire loops on the side to set the cylinder number on the 6AL, cut both loops for 4 cylinder use.
Not sure if that has anything to do with it ? or if it effects the output to the other box or something ?
CoZZm0 is offline   Reply With Quote
Old 09-04-2011, 01:20 PM   #3 (permalink)
Thanks that is the issue. Didn't think it would run if it wasn't set up properly. Guess I won't skip that page next time.
Old 09-04-2011, 03:22 PM   #4 (permalink)
Ok so I cut the wires, now the 2 step does not work. Rev right past what ever I set it at. Found someone with the same issue on another forum for a totally different car. But same issue... I checked all connections, all are connected properly. Frustrating. Could be racing today.
