Sup everybody, i drive a 1991 sentra se-r that i recently blew the motor in so i replaced it with an sr20 from a 1993 g20 and had the motor and a new clutch put in. the mechanic i had install the clutch and motor only bolted the motor on and left me to the rest so as i tied up all the loose ends and i go to start her up to hear the purr of the sr20 and she starts right up,but my clutch pedal stays basically at the floor and theres little pressure behind it,i can move the shifter into gear when i push the pedal in as normal but when i go to release the pedal im still sitting still. any input would be greatly appreciated, thanks a lot.
