SR20DE Swap into B11 Questions - SR20 Forum
Old 11-12-2011, 12:44 PM   #1 (permalink)
I have a B11 1985 Nissan Sentra that's been sitting for a few years. It runs but smokes very bad due to wornout piston rings. I dont want to waste time rebuilding the E16 engine in it because those engines have absolutely no HP or performance upgrades.It's also an automatic, and I want to change it over to a 5 speed when I do the SR20 swap.The junkyard was on the way to pick it up and take it away but I changed my mind at the last minute when I found out that an SR20 swap into a B11 sentra is possible and has been done. I've seen videos on you tube as well. The questions I have are
1. How will the fuel pump work? The fuel pump on the B11 sentras are mounted on the engine, and cars with the SR20 have the fuel pump inside the gas tank.
2.What engine mounts will I have to use? Stock SR20 mounts, B11 sentra mounts, or some kind of custom made mounts?
3.What kind of axels do I need? Stock B13 SR20 axels, or will B11 axels work?
4.Will B11 hubs work or will I need to use B13 sentra hubs? What other suspension changes will need to be made?
5. Will the B11 shift linkage work or do I need to use a B13 SR20 shift linkage?
34Diesel34 is offline   Reply With Quote
