Originally Posted by 92_B13_SE-R
In both cases if the clutch pedal is pressed the noise goes away.
Someone correct me if I am wrong, but isn't the throw out bearing spinning when the clutch pedal is pressed? If this is the case, I do not think it is the throw out bearing that is making the noise. Perhaps it is coming from the transmission.
Could you provide a little more detail about what kind of noise it is making? Does it happen at idle, at speed, both? What happens if you take the car out of gear and let the clutch pedal out?
