Aftermarket FlyWheels? - SR20 Forum
Old 11-22-2011, 02:24 AM   #1 (permalink)
Okay before any one mentions the search button... i looked but couldnt find a up todate thread.
Im looking into a lightweight flywheel/ clutch setup. i was wondering what everyone else is running flywheel wise.
what brand flywheel/weight?
any one have any bad experiances?
also how do i tell if my 96 se-R is a 108 or 109?
Drifter_240sx is offline   Reply With Quote
Old 11-24-2011, 09:21 PM   #2 (permalink)
really ***** has a opinion?
Old 11-25-2011, 03:41 AM   #3 (permalink)
If its 96 its OBDII meaning 108 tooth.
As far as what flywheel that depends on what you want to do. Most people go for the lightest possible(~8lbs) as its the quickest reving, but 10lbs fw are most commonly found.
And obviously there are brand names that people go for, but really there have not really been any flywheel realted failures in terms of if one is better then the other. It all comes out to weight pretty much.
Quick search on sr20 flywheel on ebay will net you results, take your pick.
(DD) '91 Aztec Red Sentra XE
GA16DE
5-Speed
'92 Aztec Red NX2K
SR20de (Getting ripped apart)
5-Speed
sentraga is offline   Reply With Quote
Old 11-25-2011, 08:59 PM   #4 (permalink)
thank you,
i havent seen any 8lbs ones, ive seen mostly 10 -13 lbs. btw any one know the factory flywheel weight?
Old 11-26-2011, 04:58 PM   #5 (permalink)
The b14 flywheel weighs 18.6lbs
Old 12-24-2011, 04:45 PM   #6 (permalink)
i have a 92 sentra se-r. i need a new flywheel. does anyone know if i have a 108 tooth or 109 tooth flywheel? how do i tell other then take it apart and count?
t-side is offline   Reply With Quote
Old 12-24-2011, 09:11 PM   #7 (permalink)
OBDI (any car made before 1996) is a 109 tooth count
OBDII(any car made for 1996 and after) is a 108 tooth count
Both 108 AND 109 tooth flywheels will work in OBDI SR20s
OBDII can only use the 108 tooth flywheels, otherwise it throws a CEL.
Old 12-30-2011, 02:00 AM   #8 (permalink)
thanx for the help you all
D/D project
-96 200sx se-R sr20 powered...
Looking for 200sx/sentra carbonf fiber parts
