What is this? - SR20 Forum
Old 01-20-2012, 09:55 PM   #1 (permalink)
What is this?
Circled in yellow
yes im a bit of a nub right now.. but im deleting things in my sr20 and was wondering what this is.
Hard to search for info on it when you dont know the name of it
eskimo is offline   Reply With Quote
Old 01-20-2012, 10:51 PM   #2 (permalink)
S12 NUT
Oil separator for the crank case vent on the block.
1987 Nissan 200SX/Silvia (S12) Specs:
  • SR20DE+T (94 S14, VCT)
  • 9.5:1 Compression (Sentra pistons)
  • T25 @ 11PSI
  • 450CC DeatschWerks Injectors @ 60PSI (528CC/min)
  • Bosch 023 Fuel Pump
  • MegaSquirt Extra 029y4
  • Custom FMIC
  • Currently maxing out injectors!
seishuku is offline   Reply With Quote
Old 01-21-2012, 03:55 PM   #3 (permalink)
thank you
I see some people put a breather on the oil separator and then on the crank case
how does this effect it?(oil separator and valve/crank case)
Old 01-21-2012, 07:03 PM   #4 (permalink)
S12 NUT
Well, as it's name implies, it separates oil from the air being drawn from the crank case.
I wouldn't remove it, because it helps keep oil residue out of the intake.
Putting a breather on it wouldn't be the right choice, when the PCV valve is allowing a vacuum on the crank case, the air wouldn't be metered by the MAF sensor.
Old 01-21-2012, 07:31 PM   #5 (permalink)
ok thanks,
but the it servers the same purpose as a catch can?
Old 01-21-2012, 08:54 PM   #6 (permalink)
S12 NUT
Yep.
