cruise control not working after 5speed swap - SR20 Forum
Old 01-29-2012, 07:10 PM   #1 (permalink)
hey peeps, my cruise control is not working after 5speed swap, I now have P11 tranny and need to figure out what wires to make it work...
thanks in advance, Bruce
1992 SE-R
SE-R Organizer and event guru
badv is offline   Reply With Quote
Old 01-30-2012, 09:53 AM   #2 (permalink)
eric96ser's Avatar
Feedback Score: 29 reviews
Missing the clutch switch.
The community is here.
Old 01-30-2012, 12:45 PM   #3 (permalink)
eric, please give me a little more info, I did not do the swap,
thx
Old 05-10-2012, 04:53 PM   #4 (permalink)
Don't know if this helps, but when my cruise went out on my 1993 SE-R [ the cruise light still worked ] I found it was a faulty brake switch which cost $33.50. plus $90. labor [part#25300-62JOE SWITCH ASM] My philosophy: I would rather work harder, and make more money, at doing what I know how to do well then waste a bunch of time doing something I don't know how to do at all. I took the car to a Nissan Service Center. No headaches, money well spent!!!!!!!!!!!
m111chael is offline   Reply With Quote
Old 05-10-2012, 10:52 PM   #5 (permalink)
Shift_2.0
Feedback Score: 49 reviews
Yep,check the clutch switch first it is on the pedal.
Look under there at the pedals and you will see them.There are 2 one to start the car(usually bypass that one on my cars),and the other for cruise.They have a plunger that goes in and out.
When you start to depress the clutch ,it makes the cruise shut off,so you dont overrev it.
The one one the brake...same thing.When you press the brake pedal,it shuts off the cruise.
[QUOTE=classicaddict;1807101]ebay coilovers are about the same as using dooky as brake pads
eggman is offline   Reply With Quote
