HELP! speedometer/cruise control not working - SR20 Forum
Old 02-04-2012, 04:21 PM   #1 (permalink)
So i did a clutch change in my nissan 200sx, after hooking everything up i realized the speedometer was not working, then today i realized the cruise control was not working. Could this be due to a faulty speed sensor? There was one connector that plugged into the bottom of the trans i might have pulled a wire or something, looking for opinions, or does anyone know exactly where the speed sensor is located on this thing?
xkyxlxex is offline   Reply With Quote
Old 02-10-2012, 03:08 PM   #2 (permalink)
Drivin' my life away. . .
The speed sensor is at the front of the transmission (by the radiator) in line with the flywheel (it counts the flywheel teeth as the engine turns). There is one small bolt that holds it in place and a two wire connector (I think).
RockAuto has a closeout sale on them, if yours is missing.
"If everything seems under control, you're just not going fast enough." - Mario Andretti
Old guy is offline   Reply With Quote
