so how do i check for idle screw clogs and fix them? the base idle screw barely affects the idle at all when in timing mode. i can get the idle down from 1500 to 1250 rpm, but that's about it - which is why i haven't been able to adjust my timing yet
Try to adjust your timing at 1250rpm. If your timing is off, it can bring the idle down too. Adjusting timing some, may bring your idle down to spec.
My problem. 93 NX with BB DET - USDM ECU and emanage. TUned right (been tuned the same way for years). When the engine is cold, it will not idle (450-600 rpm). Once I reach operating temperatur, it's pretty good, but not great. Sometimes idles at 1200, 1600, 900, jumps up and down, whatever it feels like. Timing is 15 degrees. No idea what the problem is, but it's getting on my nerves.
I agree with this. This may be too obvious, but also make sure your throttle cable is not too tight - that would give an artificially high idle.
and I agree with this. My throttle cable was too tight after I did my spacers, leaving the throttle body valve open slightly, causing my car to idle at 1500+ rpm. outlaw spacers give very little room for adjustment after installation of the throttle body spacer. I just got used to the tightness, easier to get the power I need down low
I have a 1995 200sx se-r and lately it seems to want to stall out when I throw it in Neutral, and slow down to a stopsign/light, it starts to slowly bog down and dies. Not all the time, maybe 10-15% of the time. If I press the gas while in Neutral while I'm slowing down it seems to correct the problem. Dont really have a problem either other way, just when the cars cold or the first time I'm running it, kinda gives me problems too. Any help would be very appreciated. Loved the info in the beginning, and going to use the hell out of it if anyone doesnt know what I can do about THIS particular problem.
God dangit. 91 SE-R. Uncommonly high idle.... I'm talking 4250. There is a crack in the hose that comes from the airbox, but that should prob. weaken the car.
I've searched , but all of the threads have been about low idle.
heres my idle issue, my car starts fine cold in the morning, and i just mess with the gas when its cold and starts to idle irratically only when its cold, but when its hot it idles fine with no jumpy idle, so i have like a cold idle problem
and in the morning when i rev it cold it misfires starts burning up raw fuel, black smoke for a bit, then cold idle starts to work good,, what could it be, FPR??? ive cleaned out the aac valve regrounded maf, and still the same...
2005 Nissan Titan SE 2X4 my DD
1991 clean white SE-R -Bone stock- another DD (second owner)
[b]91 Mint SE-R (third owner)
Mods: Black, Very Clean, Turbo. -weekend warrior-
93 Mint Sentra E--VE Soon (original owners since late 92)
Any exhaust leaks at your header/exhaust manifold will result in a crappy idle and possibly hesitation. The O2 sensor is getting air from outside the engine, and it will be very confused.
Also, if the Engine Coolant Temperature sensor is getting a faulty reading, either a bad sensor or wiring, the motor will run like ass. Crappy, fluctuating idle, possibly dieing on you, bad hesitation under load or any time you attempt to accelerate. The ECT controls a "choke" that dumps extra gas when your engine is cold. If the ECT is faulty in any way, it will dump gas when the engine is hot. Flooding the engine.
2 cents
where should a normal idle be?
i read people have it anywhere between 750rpm-900rpm but when mine is anything under 1000, the car starts to sputter
i've played with the IACV and still have the same issue
Originally Posted by brooklyn nx
1: Dont give up 2: You need to get a job that pays a little better 3:Get a girlirfriend who supports your cause. I got 2 cars that need help and no steady work but that dont stop me from getting a little done at a time,If you love your car and love what you do youl get through it.
ok guys i just cleaned my TB and got rid of my EGR stuff now my idle goes from 400rpm and almost dying on me to about 1500rpm continously and is driving me nuts....i checked basically everything on the list.
what about cleaning the TB messes up the idle? maybe i migh tof left a hose to loose?
Sleeper: Its what made the Trojan Horse so popular back in the day.
i put on a short ram on my car. when i start it up after its been off for a few hours or over night it idles high. so i back out of the driveway it runs fine.. i shift into first gear and the car jumps like its got a 2 year old behind the wheel, like im pressing the gas then letting off over and over causing it the jump. so i shift into second and it does the same for a sec. it only does this when its warming up. cometimes when i start it it dies so i have to rev my engine. any suggestions?
__________________ I tested positive for OOOND: Overactive Obsession Over Nissans Disorder
hi,can u help me,my black top 180 wont rev over 2000 sumtimes,it comes into it when car is stationary after a drive.i have disconnected the maf sensor while its doing this,and its still the same,i cannot figure out my problem,wait for reply,tanx
spacegoer25, you might want to search the forums for someone else with the same problem. If that doesn't work, you should make a new thread in this part of the forum. I don't know if this thread is the right place for your question. Not many people will see it here, and it seems to be off topic.
i have had ongoing idle issues with my car that i have yet to figure out.
ive
checked tps
cleaned aac valve
replaced aav valve
adjusted tps in voltage specs
checked for vacuum leaks
i have -18in hg vacuum
tried to get it into timing mode to adjust timing to stock base and got no results
im running FOR ENGINE MANAEMENT:
AEM EMS
AEM WIDEBAND UEGO
AEM 3.5BAR MAP
AEM AIR INTAKE TEMP SENSOR
i cannot figure what it is
the idle isnt steady it slightly goes up and down at around 1300rpm, WILL not go any lower, adjusting my AAC valve makes almost no difference in the rpm idle. like i said i cleaned the aac and replaced the aac and still no results in anything
also my aem ems uego always seems to never be 100% stable it always is jumping from 16:1-17:1 back and forth back and forth at idle, never stable
I am about thru with this car this year. I checked the MAF wiring and rewired it. Maybe bad gas, Seafoaed it. Changed fuel filter. Nada. Last week, jiggled the coolant temp sensor wiring, reproduced the symptom, but unable to do it again. What happens is the engine temps take forever to raise even in this heat. And now it is dropping at idle and the idle gets lopey. Any ideas where tow check next?
I cleaned the T/B, and the MAF was regrounded years ago. I am wondering if ShawnB had it right with the ECT. Gotta check the fuse, EGR and the sensor/wiring next. Seriously thinking it is the ECT.
Originally Posted by sonny
Check your thermostat. Mine was stuck open, car took forever to warm up, and the temp gauge would drop at higher speeds in cooler weather, or even normal days.
I've never had a Nissan with a bad thermostat, but it was, and it cured a host of woes including really crappy running when first starting the car - the engine just wasn't warming up circulating all that coolant.
May sound whacked, and I otherwise wouldn't believe it if it hadn't happened to my B13.
hth
__________________ Former SCC Project SE-R
'91 B13 Black, JDM 10:1 CR SR20DE, Custom Intake/MAF, 2.5" SSAC Header, Progress Coil-overs 350F/250/R, 3-way adj. 30-mm Progress FSWB, 22-mm Progress Rear Sway, Ground Control Camber Plates, Front strut and FW braces, Progress control arm brace, Energy Suspension bushings, Wilwood Brakes, Motegei Traklites 15x7, Kuhmo MX tires. Team Progress
