Old 04-02-2003, 02:45 PM   #1 (permalink)
POWER HUNGRY
sensors
i just got a jdm motor,can someone please tell me what the two sensors are located right by the oil filter,one is a two prong the other is a one terminal type. thanks for the help.
white_91_ser is offline   Reply With Quote
Old 04-02-2003, 04:05 PM   #2 (permalink)
Trader Rating: 35 (100%)
Both are for coolant temperature. The single spade connector is for the dash gauge. The two prong connector is the coolant temperature sensor for the ECU.
Steve
'92 NX2000 (resting peacefully)
thepep is offline   Reply With Quote
Old 04-02-2003, 05:51 PM   #3 (permalink)
Tired!
coach's Avatar
Trader Rating: 42 (100%)
I don't think those have to swap over do they?
Brent
Old 04-02-2003, 06:53 PM   #4 (permalink)
eric96ser's Avatar
Trader Rating: 16 (100%)
They do have to be swapped over if you want the car to run right.
Old 04-02-2003, 11:20 PM   #5 (permalink)
Ben
www.motorists.org
Ben's Avatar
My understanding was the single spade one for the dash gauge was the only one that needed to be changed out. In all my JDM/DET swaps I've done I've only changed this sensor once and this was because I put a highport in a B14 and the plug on the harness didn't match the highport sensor, so I used the old one so that it would plug in.
99.5 Audi A4 Avant 2.8L quattro 5-speed
03 Honda Odyssey EX-L
Ben is offline   Reply With Quote
Old 04-02-2003, 11:31 PM   #6 (permalink)
Tired!
coach's Avatar
Thanks Ben. I learn something new everyday it seems. I have to do that on my DET before I drop it in.
Brent
