Old 04-24-2003, 08:41 AM   #1 (permalink)
Difference between sr20de & sr20det
Hello!
I'm new on this forum; sorry but i speak just little english (i'm french!!)
So i want to know what are the difference between those engine, because i can be interest tu put a Turbo on my sr20de... (like Gti/R...)
Thanks!!
D'sound is offline   Reply With Quote
Old 04-24-2003, 11:46 AM   #2 (permalink)
Tired!
coach's Avatar
Trader Rating: 42 (100%)
The maind defferences are the compression ratios between the Bluebird DET and the regular SR20. Now, when it comes to the GTi-R SR20det you have even lower compression at 8.3:1, quad throttle bodies, larger oil pump, oil squirters all built onto the block. I am sure other people will chime in.
Brent
Old 04-25-2003, 03:01 AM   #3 (permalink)
Thanks for your answer!
So Do you think it's difficult to put a Turbo on the sr20de? Is it necessary to change a lot of pieces? (oil pump, cams...)
Nissan 100 nx 2l16v - sr20de
http://membres.lycos.fr/dlpdsound/hp...ge%20copie.jpg
Old 04-25-2003, 03:47 AM   #4 (permalink)
Learn to swim
I thought U13 had squirters too?
-Bill Hicks
UNDRCOVR is offline   Reply With Quote
Old 04-25-2003, 11:16 AM   #5 (permalink)
Coropate greed hater
They do.
-The Usual Suspects
Old 04-25-2003, 12:42 PM   #6 (permalink)
Boost in full swing...
Plenty of posts and threads
Do a serach. There are plenty of threads and posts on this topic over the years. Take a trip to the Turbo forum and even this forum too...
Boost...Its whats for dinner...
'97 200SX SE-R BB DET | JWT ECU | JWT Custom Clutch Kit | UR Pulley Set
nismo200 is offline   Reply With Quote
