Old 10-18-2003, 05:16 PM   #41 (permalink)
iNGEN
iNGEN's Avatar
The answer is four simple words: Ramp Angle and Enertia.
The steeper the ramp angle at a given resistance the greater the likelihood a valvetrain component will separate from its connecting piece(s).
The real difficult part is that a manufacturer may alter the ramp angle at the top or bottom of the roll, so there may be two ramp angles on any one profile. Float can result from deflection or enertia, either at the top of the lift.
So unless you can find the ramp angles of attack or ramp angles of incidence you are gonna have to take the manufacturers word on what needs upgraded springs.
Matthew "iNGEN" Woods
SweetPea has to go. 61k and clean as a whistle. Lots of extra parts including rebuilt turbo thrown in. PM me for details.
iNGEN is offline   Reply With Quote
Old 10-18-2003, 06:58 PM   #42 (permalink)
chris13bsr20
rotorhead
Originally Posted by Rico55
does anyone know the answer to the above stated question. because i am interested to find out if the stage 2 cams from zex(in. 268 duration + 11.43 lift and ex. 278 duration + 11.53 lift) really need a valve spring upgrade. any help would greatly be appreciated. TIA...
p.s. i know the list says that it can be used with stock valve train but, i went to nipponpower.com and the website reccomends a valve spring upgrade just want to be sure before spending any money on a product.
Rico, I'm considering the same cams. I think Comp Cams went a little overboard on the exhaust cam specs (probably because Zex is selling them and they want to push nitrous use). I was thinking the intake cam will be fine but exhaust cam scares me with stock valvetrain.
88 RX-7
95 Protege
chris13bsr20 is offline   Reply With Quote
Old 10-19-2003, 04:25 PM   #43 (permalink)
Rico55
WATUFAKA "CYDAL Racing"
that might be true about the exhaust cam, since zex is known more for its nitros setups.
99 SE-L Project Continues...
Eric
Rico55 is offline   Reply With Quote
Old 10-24-2003, 03:15 PM   #44 (permalink)
kleensleeper
The NX crew.
Maybe i'll give the intake comp cams a try.
91 NX2K U13 DET....3071R powered
12.00 @ 122mph
Stock b13 tranny ftw.
Tuned by the KeepLabs crew.
kleensleeper is offline   Reply With Quote
Old 10-29-2003, 10:53 PM   #45 (permalink)
iNGEN
iNGEN's Avatar
I found some detailed specs for you on some of the OE cams:
Year In Opens In Closes Exh Closes Exh Opens
91-93 13 55 3 57
95-97 5 47 3 57
Forum won't hold my tabs so just re-space the text.
Old 11-01-2003, 01:12 AM   #46 (permalink)
mYseRgOesvrOOm
I need me SE-R
haha. who bumped the sticky? haha.
we really need some more info on these ZEX cams. seems like there's a ton of interest...in a way. i want to know more at least...
mYseRgOesvrOOm is offline   Reply With Quote
Old 11-01-2003, 08:31 PM   #47 (permalink)
kleensleeper
The NX crew.
I ordered a set last week.I'll let you know how it goes. 264*(in)274*(ex)
Old 11-01-2003, 08:35 PM   #48 (permalink)
mYseRgOesvrOOm
I need me SE-R
sweeeet. . haha
Old 11-01-2003, 10:48 PM   #49 (permalink)
chris13bsr20
rotorhead
Nice, are you going to dyno?
Old 11-02-2003, 06:26 PM   #50 (permalink)
Rico55
if i am correct that is the stage 1 cams right? BTW keep us posted on them after you install and break them in...
Old 11-16-2003, 01:22 PM   #51 (permalink)
FastNX
Professor Dingbat
the HKS step one is listed as 256° and 264°
Old 12-26-2003, 02:58 PM   #52 (permalink)
sakerocket1
owned by SE-Rs!
Originally Posted by Calum
I've been compiling a list of all the different cam grinds I've wandered across, with part numbers and prices if I could find them for sale (not that that is a a garuntee you can actually buy them, lol). Some of this I got from the manufacturers' websites, a couple from bugging places that sell 'em, and a couple from various other sources. I know there are other grinds out there, but if they're not listed I havn't had any luck on getting specs. If you spot an error (or twenty) or know of others, post it up and I'll add it to the list. I know I'm missing some of the stock grinds.
Anyways, thought you guys might enjoy it.
A big list of cams
I found more cams from Kent
http://www.needforspeed.co.uk/pages/...PartType=CAM01
and here is some more info on piper too
http://www.needforspeed.co.uk/pages/...PartType=CAM02
Nick McCollom
99 Infiniti G20
93 Nissan NX2000 14.027 @97.98 (N/A) I wish I had time and money again, this little car has sat for 2 years now. I do miss driving it bad. It will be back soon though faster than ever.
http://www.cincyclubclub.com/lilly/littlefamily.jpg
sakerocket1 is offline   Reply With Quote
Old 12-27-2003, 11:47 AM   #53 (permalink)
Calum
soylent green is people
Calum's Avatar
Approved vendor
Trader Rating: 19 (100%)
Hey cool. I didn't have the Kent cams.
I've got a whole bunch of stock grinds to add, plus some I found from a company in Belgium called Cat Cams:
http://www.catcams.be/index.htm
Old 12-27-2003, 01:45 PM   #54 (permalink)
sakerocket1
owned by SE-Rs!
Ive seen the cat cams but I forgot about them.
Old 12-30-2003, 09:12 AM   #55 (permalink)
AaroNX
I'll be getting the Zex stage 2 cams in a week or two. I'm getting them for $387. Do you guys think I will have to change the springs?
http://phatboyaudioonline.com/
1993 NX2000-5SPD SWAP, 2120lbs. JDM Motor, Calumsult Realtime ECU, Brian Crower STG 3 cams, CP XTP 9.2:1 pistons, NX DP-100 shot, Prothane Mounts, ACT Xtreme/street disc, PR CAI with JWT POP, SSAC with 2.5" downpipe, Dynomax 3" muffler, Outlaw Intake Spacers, OEM wires with ngk plugs, UR Pulleys, Walbro 190, ST springs with KYB's, Xstatic Batcap, Axis maglites
Old 12-30-2003, 09:57 AM   #56 (permalink)
Rico55
you should be o.k. with your stock valve springs, i think if a person runs a stage 3 kit and up (like my stage 4's that i still have to install) you would have to upgrade the springs.
Old 12-30-2003, 11:25 AM   #57 (permalink)
Calum
Calum's Avatar
Approved vendor
Nah, they should be fine with the stock springs. Who are you buying them from?
Old 12-30-2003, 11:49 AM   #58 (permalink)
chris13bsr20
rotorhead
I saw the stage 2's for $370 at Racenet Performance. Most of the sites that sell them say valve springs are recommended for stage 2 but not required but the Comp Cams site says "needs aftermarket springs" for every grind except 58100??
Old 01-01-2004, 10:51 AM   #59 (permalink)
AaroNX
My friend has a little shop, he gets stuff from Tennessee Speed Sport Wholesale.
Old 02-05-2004, 08:40 PM   #60 (permalink)
Calum
Calum's Avatar
Approved vendor
Wanted: Someone with a little freetime who would be willing to do a little updating to the list. I have a bunch of new info but just havn't had the time to put it all in. Anyone intrested?
