Old 11-14-2005, 03:22 PM   #81 (permalink)
randyo156
Does anyone have any info on jwt s1 cams?
randyo156 is offline   Reply With Quote
Old 11-20-2005, 06:05 AM   #82 (permalink)
jetpilot
Hi guys,
For the past 6 months i have been braking my head over the set up that i would like to go with my SR20 (highport). I am set on the bottom end where i will go oversize on the pistons... but my problem right now is the head gear... I have searched on JWT for info about the cams but unfortunately cant fine what i was looking for.
I am looking for specific info on the cams like S1 is good for mid-range or poor in top end (note: this is an example i am not saying that this is true.) That kind of Info is very important to me when sellecting cams. It would be impossible for me to buy all JWT cams and test them out.
I am going for a C-series cams. I would like a overall performace of low-end, mid-range, and top-end this not only on the dyno but also on the street. Can anyone help me with this kind of info?
Cars:
  • 1991 Nissan Sunny GTI (SOLD)
  • 2001 Subaru Impreza
J-Tuning
jetpilot is offline   Reply With Quote
Old 11-20-2005, 09:43 AM   #83 (permalink)
hpro123
SE-R GREEK
Sure...
S1 and S2 are out of the picture since you will not find them anywhere anyway.
Your options are S3, S4 and S5 (none of them NEEDS springs & retainers).
or
C2, C3.
S3 have the most low-midrange and fall off after ~ 6800 rpm if I remember correctly.
S4 haveless low-midrange and fall off after ~ 7200 rpm if I remember correctly.
S5 even less midrange (low is probably out on those) and keep chugging until 7600 or more.
C2 are probably the best for your needs. Better than S4s from midrange and up, equal probably to them down low. Still, C-series are not exactly advertised as street-friendly.
Best bet is to actually serach and find dyno runs of those.
PS. How are the T1Rs on your car? Happy? And are the Superleggeras 15x7? What dimension is the tire?
Old 11-20-2005, 10:15 AM   #84 (permalink)
jetpilot
Originally Posted by hpro123
Sure...
or
C2, C3.
Sup Chris,
Thnx for your insight in this matter bro, i really appreciate it. About the tires and wheels they are not in the car yet, still have to purchase them. I will be getting 16x7 and 205/40/R16 ... I will let you know as soon as they are under the car...
Thnx bro
Jairo
Old 11-20-2005, 11:54 AM   #85 (permalink)
hpro123
SE-R GREEK
Jairo,
you may want to search threads started by CHOADERBOY in 2004. Basically, look for HS Gen6 testing, a thread with "woo hoo 200.4" in its title etc. He talks about large cams and how they behave when using a large header and exhaust. He compares directly S4 with S5 and throws in some C2-C3 with hius opinion on them.
As for the 16x7 dimension, just make sure it will not touch anywhere in the rear (either fender or the strut on the inside). They do fit but it may be close, especially if the tire is really wide.
Old 11-20-2005, 11:56 AM   #86 (permalink)
hpro123
SE-R GREEK
Never existed except as a protoype. S2 where the first to be sold commercially.
Old 11-20-2005, 12:24 PM   #87 (permalink)
jetpilot
Jairo,
Sup Chris,
In the 200.4 thread Mike has given me some advise on the cams and recommended C1's back then. But tis the knowledge behind it thats what i am after just like the way you have explained to me.... thnx for the search tip
As far as the wheels go .. i have 17x7 on now and i have noticed that on my car they are about 2 cm in the body compared to the front ones.. it looked odd at firts but i soon noticed that lots of nissans are like that... so all good
Jairo
Old 11-23-2005, 07:08 PM   #88 (permalink)
jetpilot
Ok guys here's another one .... Whats the deal with a smaller exhaust cam then the intake one .... and is there a rule of thumb how to apply this?
Old 11-23-2005, 09:35 PM   #89 (permalink)
SUPER"FAKA"MAN
Blast From The Past...
Trader Rating: 23 (100%)
If you plan on going N/A then you might want to run a larger intake cam. Here is a example: people with lowport sr20's use the larger intake cam from 91-93 se-r's. So it might be possible to use a S3 intake and S2 exhaust cam's maybe even a S4 intake and S3 exhaust cam's. This is just my theory, I have never tried this myself. I do know that if you use a larger exhaust cam than intake cam, it would be bennifical for nitrous user's.
Eric?!
Support your Forum & Vendor's
SUPER"FAKA"MAN is offline   Reply With Quote
Old 12-04-2005, 05:22 PM   #90 (permalink)
jetpilot
thnx for your reply i appreciate it...
i took it upon myself to contact JWT and ask them about this "bigger intake cam then the exhaust cam theory" and they advised against it ....
Old 12-04-2005, 07:04 PM   #91 (permalink)
hpro123
SE-R GREEK
And they are correct of course. Whenver this approach is tested on an SR20 it does not work as well as same intake-exhaust.
Old 12-05-2005, 05:22 AM   #92 (permalink)
dsp26
NXTACY
Wade Cams (Australia)
www.wadecams.com
eg
Grind 1598c
264 In/Out 0.444 Lift
Theres a few more on their site but thats just an example.... AU$560ish a a pair
-~10.8:1 CR (2mm Shave) + 17° timing
-WAI: Aluminium Intake w/ OBX Foam POD
-Hurricane Headers w/ 1.75' Secondaries
-2.5' Mandrel Bent Cat Back system.
-KYB GR2 Struts on Stock Springs
-Prothane Motor Mount Inserts
-NGK Iridiums (BR6) + Top Gun 8mm Leads
-Shortshifter + Nismo GK
- Crane LX91 Ignition Coil
-Adj. FPR @ 45psi Vac On
-JDM Inlet Manifold (No EGR!!!)
dsp26 is offline   Reply With Quote
Old 12-06-2005, 04:33 PM   #93 (permalink)
GTI-R34
SR20DET POWERED
Lets say it is a turbo motor instead does it make a difference or would you guys also advised against it ,
Nissan pulsar GTI-R 92
GTI-R34 is offline   Reply With Quote
Old 12-06-2005, 05:27 PM   #94 (permalink)
Rob
VQ35 Powa!!
just curious as to where you heard that. my s4s pull hard all the way to 7750..
218WHP/228 TQ WAI only 02 6MT A33B
Old 12-19-2005, 07:28 PM   #95 (permalink)
venom2727
www.wheelsjamaica.com
tryig to get it touch with calum about the daughterboard PM me..i was trying to PM u but yur PM box is full .ASAP
venom2727 is offline   Reply With Quote
Old 12-20-2005, 10:47 PM   #96 (permalink)
sonny
SR20DEtroit
Trying to decide between S4s and S5s. With a JWT tune (7800 rpm cut, IIRC) on a lowport w/ IHE, is there any advantage of going w/ the S5s instead of the S4s?
sonny is offline   Reply With Quote
Old 12-28-2005, 09:25 PM   #97 (permalink)
Aero Deck
GUNT SMASHER
Trader Rating: 4 (83%)
I have read here that S4's are the way to go with a T25. How would S3's be on a T25 motor? What is the difference in the way the two act with a T25 and what is the difference in idle? My car has the Prothane mounts all around.
Built, not bought.
Aero Deck is offline   Reply With Quote
Old 03-12-2006, 08:38 PM   #98 (permalink)
s13srmadness
does anyone here know for sure the specs on the cams out of an s13 sr20det? (from a silvia, obviously)
pm or email if you do.
thanks.
s13srmadness is offline   Reply With Quote
Old 03-16-2006, 09:30 PM   #99 (permalink)
Jaketips42
Making the G breathe hard
Jaketips42's Avatar
What about the UK SR20 10:1 cams? I thought Dre said they aid in getting the UK SR20 150hp.
**Snap On box on ebay**
Old 09-09-2006, 08:09 AM   #100 (permalink)
zerogravity
Ser Charles
zerogravity's Avatar
Good reading!
www.cfxpaintworks.com
"There is one thing man should truly fear...it is the INDIFFERENCE of good men..."
My Set Up:
Motec Exhaust*Walbro Header*MSD Rims*Jim Wolf Custom Paintjob*Injen Tires*Mugen Glove Compartment*MazdaSpeed Bridgeport*Edlebrock Exhaust Bearings*Calum Power Mirrors.
Damn My Sentra Hauls!!! 93 Whp of PAIN!!!
zerogravity is offline   Reply With Quote
