Old 11-01-2006, 11:15 PM   #101 (permalink)
EPSentra
Maybe I'll revive this for a couple questions....
I see that the HKS Stage 2 and 3 cams have the same specs, save for the small Stage 2 intake. Seems like there would be a difference??
Have any of you seen results or used reground cams on an SR20? How did they work? I'm considering it as I have contact with a grinder here in the PNW.
EPSentra is offline   Reply With Quote
Old 11-11-2006, 06:55 AM   #102 (permalink)
Matt_S
Can anyone tell me the std lifts and duration for the RWD S14 SR20DE?
Im having REAL trouble finding them. Ive found S13 SR20DE specs but not the S14 with VVT
I need to know soon. I just want to know if its gonna be worth using the DE inlet cam (afaik the exh are the same between DE and DET) in my DET build. And if so should I use the DE springs too???
Thanks.
Matt_S is offline   Reply With Quote
Old 11-11-2006, 12:54 PM   #103 (permalink)
trinisentra
Originally Posted by 93W91SER
What about the UK SR20 10:1 cams? I thought Dre said they aid in getting the UK SR20 150hp.
what is the stock number printed on these cams? Does anyone know..
trinisentra is offline   Reply With Quote
Old 11-12-2006, 12:26 AM   #104 (permalink)
hpro123
SE-R GREEK
Thanks.
S14 SR20DE (not DET):
Intake: 248 deg, 10mm, lobe center 130 deg.
Exhaust: 240 deg, 9.20mm, lobe center 113 deg.
Exhaust S14DE/S14DET are the same.
Intake from DET is 240 deg, 9.20mm, 126 deg lobe center.
Old 11-13-2006, 07:18 PM   #105 (permalink)
Matt_S
Thanks man! I owe you!
So, any benefit in fitting the DE cam to my DE then???
Old 11-14-2006, 06:17 AM   #106 (permalink)
hpro123
SE-R GREEK
De to DE?
Anyway, it is a bit more radical (+9% lift) so I suppose you can use it for some gains. Altough it is a turbo engine I do notthink 8 more degrees of duration would screw up anything.
I do not think you need any springs since the same 8 more degrees of duration should smooth out the ramp of the cam. Just in case though, if you could find DE inlet valve springs you would be safer.
Old 11-14-2006, 11:19 AM   #107 (permalink)
Matt_S
Yeh, well basically Id use the DE head with the DET Exh valves (sodium filled) and cam.
Sorry about the missing T
Well spotted :p
Old 01-13-2007, 01:49 AM   #108 (permalink)
SpecVKiller18
SpecVkiller
Hey I was wondering if a put s4 cams in my sr20de do u think ill pass emission test??
SpecVKiller18 is offline   Reply With Quote
Old 01-13-2007, 02:00 AM   #109 (permalink)
thomas_xsr
how much whp do you get from installing s4 cams..please some one pm me and let me know..i would be truly grateful. thanks
thomas_xsr is offline   Reply With Quote
Old 05-23-2007, 12:03 PM   #110 (permalink)
Nismo87SE
Just to let everyone know the link is down for the cam listing.
91 Nissan Sentra SE-R: KYB AGX's, eibachs, prothane mounts, ES suspension bushings, addco RSB, FSTB/RSTB, CAI, JWT C2/ECU, 3in B-pipe, UR UDP, nitrous
Best ET: 13.57 @ 99mph
Nismo87SE is offline   Reply With Quote
Old 06-08-2007, 05:24 PM   #111 (permalink)
SBR240sx
who wants cams ?
SBR240sx is offline   Reply With Quote
Old 06-08-2007, 08:01 PM   #112 (permalink)
SENTRASER
Drive it like ya stole it
SENTRASER's Avatar
Trader Rating: 33 (100%)
I noticed the link was down, bummer.
~Ryan
1992 NX2000 Hardtop
1989 B12 AWD wagon
Originally Posted by chriscar
Old 09-18-2007, 10:24 AM   #113 (permalink)
2sNoAR
i need CAMS!!! i have decided to go all motor on my car and i need cams, help me out. this is my first project, thanks for the help.
nx2000 2.0L sr20de
2sNoAR is offline   Reply With Quote
Old 09-18-2007, 10:39 AM   #114 (permalink)
2sNoAR
would i be able to use aftermarket cams for the early se-r's or the 200sx se-r's for my 93 nx2000??? i need help in building my project, i want it to be ready by summer. i want to beat my buddy's eg, lol. he's got a b16 swap and minor bolt-ons...
Old 09-18-2007, 10:41 AM   #115 (permalink)
gomba
Endless Turbo Preparation
archive-0wned..
http://web.archive.org/web/200509101...32/camlist.htm
list archived..link works.
'95 200sx SER - Loading Turbo.exe |!!!!.................| 22%
"He who asks a question is a fool for five minutes; he who does not ask a question remains a fool forever” - Chinese Proverb
gomba is offline   Reply With Quote
Old 09-18-2007, 05:38 PM   #116 (permalink)
broeder
I have C1 cams, tit valve springs and retainers. I am wanting to put these in because I've had them for a while.I am running a F-Max kit w/ T3T4. My compression is 8.5/1. I am gonna put my low port head on my det block. I was wondering if anyone knows if these retainers will work w/ the 5J sodium filled exh valves. I hope someone can give me an answer.
Brandon
broeder is offline   Reply With Quote
Old 10-22-2007, 05:11 PM   #117 (permalink)
boss_SR20DE
can you help me please,the cam specs of sr20di are the same with sr20de for pulsar??
boss_SR20DE is offline   Reply With Quote
Old 10-23-2007, 03:47 AM   #118 (permalink)
hpro123
SE-R GREEK
Boss, still looking for it?
Guys in the US have never seen a Di, let alone a cam from a Di!!!
Nissantuners.gr FTW!!
Old 05-16-2008, 07:53 PM   #119 (permalink)
93specv
i learn as i go
the original link on page one, post one, no longer works
BOOST!!!!! coming soon '08
B13 PARTS 4SALE:
http://www.sr20forum.com/mechanical-...arts-sale.html
All Your Local Repair and Custom Needs:
Anthony Q
A&C Imports LLC
(603) 669-2824
e-mail: ant280@aol.com
Old 06-11-2008, 09:58 PM   #120 (permalink)
Alex_se_r
Does any one know if I can use DET cams on my 97 DE lowport head????
Alex_se_r is offline   Reply With Quote
