Hi Guys
I'm an older aussie that has a soft spot for the nissan silvia. In my case I own a 91 model of the above silvia.
Info on JDM DE SR20's is not as plentiful as for the DET's and while I have obtained the factory cam specs for PS13 from the Tomei website in Japan I would like to find out if the n/a cams used in the PS13 silvia were used in any other nissan models. The stock specs for the 91 PS13 SR20DE silvia are as follows:
Type: lash
inlet: 248 degrees
ex: 246 degrees
Lift (in): 10.0mm
Lift (ex): 9.2mm
Lobe centre angle (in): 117 degrees
Lobe centre angle (ex) 120 degrees
I'm not looking for performance cams as the silvia is used as a daily.
Cheers
Ric
