Can anyone tell me the std lifts and duration for the RWD S14 SR20DE?
Im having REAL trouble finding them. Ive found S13 SR20DE specs but not the S14 with VVT
I need to know soon. I just want to know if its gonna be worth using the DE inlet cam (afaik the exh are the same between DE and DET) in my DET build. And if so should I use the DE springs too???
Thanks.
S14 SR20DE (not DET):
Intake: 248 deg, 10mm, lobe center 130 deg.
Exhaust: 240 deg, 9.20mm, lobe center 113 deg.
Exhaust S14DE/S14DET are the same.
Intake from DET is 240 deg, 9.20mm, 126 deg lobe center.
So, any benefit in fitting the DE cam to my DE then???
De to DE?
Anyway, it is a bit more radical (+9% lift) so I suppose you can use it for some gains. Altough it is a turbo engine I do notthink 8 more degrees of duration would screw up anything.
I do not think you need any springs since the same 8 more degrees of duration should smooth out the ramp of the cam. Just in case though, if you could find DE inlet valve springs you would be safer.
would i be able to use aftermarket cams for the early se-r's or the 200sx se-r's for my 93 nx2000??? i need help in building my project, i want it to be ready by summer. i want to beat my buddy's eg, lol. he's got a b16 swap and minor bolt-ons...
'95 200sx SER - Loading Turbo.exe |!!!!.................| 22%
"He who asks a question is a fool for five minutes; he who does not ask a question remains a fool forever” - Chinese Proverb
I have C1 cams, tit valve springs and retainers. I am wanting to put these in because I've had them for a while.I am running a F-Max kit w/ T3T4. My compression is 8.5/1. I am gonna put my low port head on my det block. I was wondering if anyone knows if these retainers will work w/ the 5J sodium filled exh valves. I hope someone can give me an answer.
