Old 06-21-2003, 12:25 AM   #1 (permalink)
JDM SR20DE-Advance Timing
Does anyone know how far you can advance the timing on the jdm sr20de engines with the 10:1 compression ratio. Thanks
bluesr20 is offline   Reply With Quote
Old 06-21-2003, 02:56 AM   #2 (permalink)
It will be the same as a usdm motor. I wouldn't go over 20 though.
http://phatboyaudioonline.com/
1993 NX2000-5SPD SWAP, 2120lbs. JDM Motor, Calumsult Realtime ECU, Brian Crower STG 3 cams, CP XTP 9.2:1 pistons, NX DP-100 shot, Prothane Mounts, ACT Xtreme/street disc, PR CAI with JWT POP, SSAC with 2.5" downpipe, Dynomax 3" muffler, Outlaw Intake Spacers, OEM wires with ngk plugs, UR Pulleys, Walbro 190, ST springs with KYB's, Xstatic Batcap, Axis maglites
Old 06-21-2003, 03:41 AM   #3 (permalink)
thanks
Old 06-24-2003, 09:00 AM   #4 (permalink)
B15 Army
19*
2000 Granite SE w/pp
BodeB15 is offline   Reply With Quote
