Old 06-21-2003, 01:57 AM   #1 (permalink)
Dang 'ole nitrous junkie
Help diagnose my problem....
Ok, my motor has been acting VERY sluggish the past couple of days. Power loss is very evident, and if just feels like the motor was pinging pretty bad, and ECU was pulling timing.
Well, tonight.....was FUBAR. Was crusing in 5th gear, and decided to downshift. Downshifted to 4th, rpm's are at 4000. Motor doesn't seem to wanna go anywhere. Rev's BARELY increase.
Couple seconds later of full throttle, I hear "POP", and the motor starts knocking LOUD, and shuts off.
I crank it again, and it starts, but dies. Then, crank again, and it'll run if you give it gas.....but it knocks LOUD when you give it gas. I'm talking not like the sound of pinging, like metal on metal knock. I drove the car home, but with a SEVERE loss of power, and had to keep my foot on the gas to keep from stalling. Sounds like I'm running open exhaust manifold it's so loud.
Any thoughts?
My guess is a thrown rod bearing, maybe cracked the piston ringland. This is on a 2001 B15 SR20DE with intake, header, cams, fuel pump, etc etc with 50,000 miles
NiceGuy is offline   Reply With Quote
Old 06-21-2003, 06:38 AM   #2 (permalink)
bumo
Old 06-21-2003, 12:18 PM   #3 (permalink)
THAT SOUNDS LIKE A TIMING CHAIN PROBLEM... SAME THING HAPPENED TO MY CELICA
~~ "If you can't go fast, GO LOUD"
'97 200sx - New 17" BSA rims, Pwr tech cat-back 2 3/4", K&N CAI, 2" DropZone springs, Chrome Grill, Clear outs, Indiglo gauges, and 3% limo tint all around.
'93 Celica GT conv. - stock
Daniel2145 is offline   Reply With Quote
Old 06-21-2003, 02:27 PM   #4 (permalink)
I don't believe it's the timing chain.
Old 06-21-2003, 02:44 PM   #5 (permalink)
Shift_日産
i want the valve cover
1996 Nissan 200SX SE-R
クリストファー
•AT-MT B13-LSD swap •JWT P/P •2000SE Clutch Disc •Cusco FSTB •Hyperco Gen2 •Unorthodox 4 Pulley Set •HP Racing Header •Rota 16x7 Circuit 8 w/ BFGs •12Lbs.Flywheel •Injen CAI •Stillen POP Charger •B&M Short Shifter •91 Cam •Prothane Mounts •Magnaflow Muffler •Taylor 10mm Wires •Carbon Fiber Hood •Erebuni Body Kit •Black Healights w/ Amber corners •Redline MT90
AztekSE-R is offline   Reply With Quote
Old 06-21-2003, 02:54 PM   #6 (permalink)
Right now, I'm 99% sure I spun a rod bearing. There was a couple metal shavings in the lower oil pan, along with some silver, metal looking sludge.
Old 06-21-2003, 02:58 PM   #7 (permalink)
Pew Pew Pew
Matt's Avatar
That's scarey. I'm sorry to hear about this. Sounds like it's time for a new motor to me.
Matt is offline   Reply With Quote
Old 06-21-2003, 04:11 PM   #8 (permalink)
Coropate greed hater
It could be a lot of things if its cranking over but not starting. But if you heard a loud pop from the engine, it could be that the timing chain broke, it could be bent valves, spun rod bearing, basically something related to the engine itself, which is the same conclusion that you have come to. It's surprising the engine has died out at 50k miles, but if that can happen, then anything can. Pop the valve cover and see what's up. Maybe it could be something minor. Worst thing worst, you can get a JDM engine for dirt cheap. All is not lost.
-The Usual Suspects
Old 06-21-2003, 04:12 PM   #9 (permalink)
Tired Greasemonkey
jdm time,50,000 miles is a little low to have the engine burn up though, been keeping up on the oil changes??
Old 06-21-2003, 04:29 PM   #10 (permalink)
The motor actually runs, though. It'll stall at idle unless you give it a little gas. Although, there's a LOUD knocking noise....and very little power.
Old 06-21-2003, 04:41 PM   #11 (permalink)
Pew Pew Pew
Matt's Avatar
For the car to be into the 12's the motor had to take some abuse. It definately sounds like a rod knocking from your description. If it's that loud I would expect something to come peeking out of the block soon if you keep running it.
Old 06-21-2003, 04:52 PM   #12 (permalink)
Broke Ass
jer_760's Avatar
my car did the exact same thing died, then started knocking really loud and could only go about 30mph , i took it to a mechanic and ended up having to buy a new motor, (blew the motor)
95 200sx
sr20ve
Old 06-21-2003, 05:37 PM   #13 (permalink)
Ya, it's rod knock for sure. I'm not running it anymore. Doing a DET swap soon.
Old 06-21-2003, 06:51 PM   #14 (permalink)
Shift_日産
how much for the valve cover
sorry for the misfortune
Old 06-21-2003, 08:25 PM   #15 (permalink)
Pew Pew Pew
Matt's Avatar
Wow Aztek, don't bother letting the engine cool before parting it out I'm pretty sure he got the point after the first post.
Old 06-22-2003, 09:37 AM   #16 (permalink)
I'll probably part the motor out here pretty soon. You'll be the first to get the valve cover. Although, I was thinking about using it on the DET.
