Old 06-25-2003, 01:38 AM   #1 (permalink)
yup
how do i manually crank the crank?
simple question... but not found with el searcho...
how do i manually crank the crank? thanks
Old 06-25-2003, 01:42 AM   #2 (permalink)
sellout
Put a long extension on a breaker bar and a 22mm (i think) socket. And turn it.
93 SE-R- Former BBDET with T28, 13.1 @ 112mph. *SOLD*
whitehawk is offline   Reply With Quote
Old 06-25-2003, 01:44 AM   #3 (permalink)
Shift_日産
make a flyweel adapter if the engine is out of the car only other thing i could think of is make one for the crank pulley
1996 Nissan 200SX SE-R
クリストファー
•AT-MT B13-LSD swap •JWT P/P •2000SE Clutch Disc •Cusco FSTB •Hyperco Gen2 •Unorthodox 4 Pulley Set •HP Racing Header •Rota 16x7 Circuit 8 w/ BFGs •12Lbs.Flywheel •Injen CAI •Stillen POP Charger •B&M Short Shifter •91 Cam •Prothane Mounts •Magnaflow Muffler •Taylor 10mm Wires •Carbon Fiber Hood •Erebuni Body Kit •Black Healights w/ Amber corners •Redline MT90
AztekSE-R is offline   Reply With Quote
Old 06-25-2003, 01:51 AM   #4 (permalink)
yup
k sounds good... glad my dad has big sockets in the garage... breaker bar? just a long pipe extension on the socket wrench for leverage?
black 93 classic
Old 06-25-2003, 01:57 AM   #5 (permalink)
sellout
No, the crank bolt is in a ways, so a extension to reach in the wheelwell is used.
Old 06-25-2003, 02:45 AM   #6 (permalink)
Jesus shaved
Remove the two plastic skid plates on the front passenger side of the car that protect the oil pan (not well enough for a lot of you though ) The one further back is held on by two bolts that are actually in the wheel well. After this rear skid plate is removed, you should easily be able to see the crank pulley. Grab a large wrench or a 22mm socket, and turn it. Easy stuff.
1992 Sentra SE-R
Still under 100,000 miles...racking up a whopping 200 a month!
Mods: OBX header, ES motor mount inserts, WAI, 19* timing, Brembo rotors and Axxis MM, Clutchnet fiber/fiber clutch
To install: Hyperco Gen 2's
www.cardomain.com/id/wannaser
wannaSE-R is offline   Reply With Quote
Old 06-25-2003, 06:30 AM   #7 (permalink)
It may be easier to turn if you remove the spark plugs.
http://phatboyaudioonline.com/
1993 NX2000-5SPD SWAP, 2120lbs. JDM Motor, Calumsult Realtime ECU, Brian Crower STG 3 cams, CP XTP 9.2:1 pistons, NX DP-100 shot, Prothane Mounts, ACT Xtreme/street disc, PR CAI with JWT POP, SSAC with 2.5" downpipe, Dynomax 3" muffler, Outlaw Intake Spacers, OEM wires with ngk plugs, UR Pulleys, Walbro 190, ST springs with KYB's, Xstatic Batcap, Axis maglites
Old 06-25-2003, 10:29 AM   #8 (permalink)
eric96ser's Avatar
Trader Rating: 16 (100%)
The crank pulley bolt is a 27mm. Make sure the car is out of gear. You can turn it with the spark plugs in, but its alot harder that way.
Old 06-25-2003, 12:37 PM   #9 (permalink)
just workin'
yeah its much easier to take the plugs out so you aren't fighting compression
DnS Performance
Imported Auto Center, INC
96 g20 auto, stock
totaled200ser is offline   Reply With Quote
Old 06-25-2003, 03:27 PM   #10 (permalink)
Bitter Old Man
Remove spark plugs. Place transmission in fifth gear. Turn either front wheel.
Bruce in Houston
RIP swwwinger
Old 06-25-2003, 06:39 PM   #11 (permalink)
DBA/IT
Trader Rating: 19 (100%)
anyone try slartibartfast's method? Just wanted to know if that works *** it sounds easiest
Old 06-25-2003, 06:48 PM   #12 (permalink)
yup
yeah... turning a wheel sounds good to me... thanks for the spark plug tip... glad we could get these manual crank suggestions into the archives
Old 06-25-2003, 08:59 PM   #13 (permalink)
Bitter Old Man
For the archives...okay, I guess. Seems pretty obvious to me. But then, I've been at this for over a quarter-century <shiver>.
Old 06-26-2003, 02:53 PM   #14 (permalink)
BIG-NUTTED Classic
1fastser's Avatar
Bruce's method works fine. I believe this is how you can check to see if the viscous fluid is worn out as well...turn one tire, the other should turn the opposite way. Correct?
laterz...Jody
*DONE!*
The Beast.
Old 06-27-2003, 12:45 PM   #15 (permalink)
I am a quiter
CAUTION... Do not turn the engine the wrong way... This can and will cause your crank and rod bearings come unseated then self destruct in an untimley fassion. Just so you know.
Why put off till tomarrow what you can finish today?
njdan69 is offline   Reply With Quote
Old 06-27-2003, 01:43 PM   #16 (permalink)
Bitter Old Man
Say what?!?!?
There's no clearance for that to occur.
Old 06-27-2003, 05:26 PM   #17 (permalink)
yup
ummmm then does someone want to clarify if there is a right way to turn it???
Old 06-27-2003, 05:28 PM   #18 (permalink)
Coropate greed hater
Dude, find yo self an FSM! Actually, if you don't have one, I will send you one on CD. PM me your address and I will have it shipped first thing Saturday.
-The Usual Suspects
Old 06-27-2003, 05:40 PM   #19 (permalink)
yup
yeah i have the fsm... but it doesn't explain how to crank the engine manually, if i've missed it in the manual maybe someone could point me to it... HOWEVER if it is possible to screw up my engine as bad as njdan says it could then i would really like to know which way i should be turning it...
ooops...revelation.... if i crank the engine by turning the wheel... all i would have to do is be in fifth and turn the wheel in the direction that the wheel would roll when the car is moving
Old 06-27-2003, 05:41 PM   #20 (permalink)
wait...i have a honda?
NismoSER's Avatar
Trader Rating: 17 (100%)
The wheels should turn the same way if you have a VLSD. Open diffs will make the wheels turn in opposite directions.
Chris
'91 VVL-powered SE-RSOLD
'04 G35 6MT
'99 CBR600 F4
