Old 06-25-2003, 10:22 AM   #1 (permalink)
SR20 Freak
Whistle sound at 2Krpm
Anyone have like a whistle sound down low around 2krpm, I don't think it's an exhaust leak, although it sounds like it, I've had this sound for over 2 yrs now, vacuum & intake hoses look fine, I've gotten use to the sound, anyone have this problem?
nismo nx is offline   Reply With Quote
Old 06-25-2003, 10:36 AM   #2 (permalink)
my egg has speed holes
spnx's Avatar
Turbo spooling up?
It really does sound like a vacuum leak. Any drivability problems?
If you can't track it down yourself, I can recommend an excellent local mechanic for you.
James
spnx is offline   Reply With Quote
Old 06-25-2003, 10:41 AM   #3 (permalink)
SR20 Freak
Ha, I wish it was a turbo James, the car drives fine, I just can't seem to pinpoint the sound, my mechanic sz it's my valves.
1992 NX2000 Paul
Old 06-25-2003, 11:22 AM   #4 (permalink)
just workin'
do you still have an egr valve hooked up?
DnS Performance
Imported Auto Center, INC
96 g20 auto, stock
totaled200ser is offline   Reply With Quote
Old 06-25-2003, 11:39 AM   #5 (permalink)
SR20 Freak
No egr, it's there but I capped the valve nipples, so the egr is disabled.
Old 06-26-2003, 06:27 AM   #6 (permalink)
Learn to swim
Maybe Bubb Rubb got in there and hooked you up?
Seriously, could it be your radio? A bad ground on a radio will cause it to whistle a bit..Josh
-Bill Hicks
UNDRCOVR is offline   Reply With Quote
Old 06-26-2003, 07:52 AM   #7 (permalink)
yup
yeah does it sound like... woooooo woooooooooooo
or how about woooooo wooooooooo
seriously though... im guessing you dont have your aiv hooked up if you've plugged your egr... the aiv makes a funny whistle.... wooooo
black 93 classic
Old 08-26-2003, 10:34 PM   #8 (permalink)
NISMO
hey, my car does the same thing, i dont know why but it does, i dont care to get it fixed though cause it sounds pretty neat
blunismonx2k is offline   Reply With Quote
Old 08-26-2003, 10:46 PM   #9 (permalink)
yup
im sorry i forgot to mention this... but did the sound start when you installed a header? I've had trouble with flexpipes on ps headers. Sounds like mad crickets.
Old 08-26-2003, 11:06 PM   #10 (permalink)
sellout
Do you have an exhaust or is it stock? My se-r had that noise with the stock mid pipe and my G20's stock exhaust does that too.
93 SE-R- Former BBDET with T28, 13.1 @ 112mph. *SOLD*
whitehawk is offline   Reply With Quote
Old 08-27-2003, 10:13 AM   #11 (permalink)
SR20 Freak
No headers, stock exhaust, with a high flow cat.
Old 08-27-2003, 02:14 PM   #12 (permalink)
my car does that too! is there any pro and cons if it sounds like this?
vSpeX_07 is offline   Reply With Quote
Old 08-27-2003, 03:55 PM   #13 (permalink)
yup
a flex joint (vs a flex pipe) eleminated the whistle for me on my ps... however my whistle was through out the entire rev band... two different flex pipes were used and both made the whistle... the flex joint (ball, socket, and springs) got rid of the whistle
Old 08-28-2003, 12:15 PM   #14 (permalink)
SR20 Freak
cool, i'll try using a flex joint.
Old 08-28-2003, 06:40 PM   #15 (permalink)
Whut?That Ain't No Hondah
On my Z, when I installed hard-pipe intake pipes, I get a whistle between 2k and 3.5k. I think its just the noise of air going thru the pipes.
Maybe this is similar to your noise? Just a thought.
1990 2+2 TwinTurbo 300zx
1993 NX2000 (JDM SR20DE-T)
1.6 to DET Swap
Engine Removal Writeup
NissanWar.Com - Pick the Nice from Rice
Like Boxing? Check out FightJudge.com
Crim is offline   Reply With Quote
Old 08-28-2003, 10:20 PM   #16 (permalink)
yup
i just want to ;et you know that i can't garantee any kind of change if you were to get the flex joint welded in.... i just wanted to share with you what i experienced... good luck with what ever you decide to do
Old 08-28-2003, 10:41 PM   #17 (permalink)
sellout
I thought my whistle was the flex pipe, but a brand new one did'nt change the noise. A new catback system cured it. However, my honda accord started whistling with a new flexpipe. Who knows, any pinhole leak can cause that.
Old 09-01-2003, 01:09 PM   #18 (permalink)
yup
which is why i am suggesting that any flex pipe would make that sound... and that the only way to avoid it would be to use a flex joint... like the one that comes on the ps header
Old 09-02-2003, 04:05 PM   #19 (permalink)
mAd SE-R pOwAh
Hey, I've got that whistle too. I noticed it this morning in the parking garage. I've probably had it for a while, but never had driven through the parking garage w/ the window rolled down to hear it echo off the walls. I only hear it as I'm accelerating [slowly] in 1st gear. It kinda sounds like an electric golf cart.
It's worryin' me because I've got a clicking sound when I turn the steering wheel (not necessarily turning); and I hear a strange metallic-like popping noise from the rear. Both things seem to only occur when it's real hot outside and the car is warm.
I'm wondering if the clicking sound and whistle is the CV joint. I'm completely clueless about w/ the popping sound. I figured it was the rear suspension, but I've bounced the rear bumper up/down; re-bound is ok and no sound occurs.
Then again, the metallic-popping sound and whistle could be the stock exhaust system on its way out and the clicking sound from the steering wheel could be normal.
Anybody...?
Michael.
1995 M3 Coupe
2002 M3 Coupe
Michael-Dallas is offline   Reply With Quote
