Old 09-04-2003, 05:47 PM   #1 (permalink)
my se-r wont come out if park
ok , i have a 96 200sx ser auto. well i went to get in it the other day, and it wont come out of park. the button wont push in. so i took the to screws out of the gear shift and and moved it around and it finally went into gear.well i put the screws back in and put it in park agian and it did the same thing.
Does anyone know what it might be causing it to do this?
http://im1.shutterfly.com/procserv/4...44460000007610
"Project 200sx se-r is now underway."
boss_pc2 is offline   Reply With Quote
Old 09-04-2003, 06:01 PM   #2 (permalink)
sellout
I don't know what you took apart, but a lot of times a bad brake light switch can cause this. The brake light switch is also used to control the shifter lockout.
93 SE-R- Former BBDET with T28, 13.1 @ 112mph. *SOLD*
whitehawk is offline   Reply With Quote
Old 09-05-2003, 05:43 PM   #3 (permalink)
yeah we found the problem. but now my key wont come out of the igition. would that have anything to do with it. i know it has to be in park.
Old 09-05-2003, 06:25 PM   #4 (permalink)
men =, somethig like that happen to my borther , he has a bluebird auto, i think it was the auto cable trans try to move all the way to the front, even if it is on Pthat way loose it.
I think in the bluebird was dirty stuff accumulted on the cable , begins to remain stuck.
I hope that this can help.
primerap11 is offline   Reply With Quote
