Old 09-05-2003, 07:38 AM   #1 (permalink)
Enginerd
Two New Problems
1) When my car is at idle, i can go around to the back and listen by the muffler or look under the car, and instead of hearing a steadily flowing exhaust i hear kinda like its trying to flow but being choked every other second so its like.... hmmmm bump hmmmm bump bump hmmmm... could the cat be clogged??
2) When I leave for work in the morning my car starts up and everthing fine and I leave, but after i get out of work... ill start my car.. and try to start moving forward in 1st and it will act like it wants to stall so ill immediatly push in the clutch and it will do it for another split second before the rpm's will shoot up to like 2,000 then everything will be fine... any ideas???
thanks
91 Sentra SE-R
Fujimo is offline   Reply With Quote
