well there is a search button that will unload 1000's of thread about this very same subject. but your answers are, yes,yes,and yes,a stock se-r block will hold about 22psi with very good gas and no detanation
97 200sx SE,electric water pump, GT35R,PROTECH equel lenght manifold,
stage v portedhead, ferria over sized valves ,je 10.4.1, cunningham rods ,total seal rings ,a1000 aeromotive fuel pump ,96lb injectors, o2 stage 2 ,Q45 t/b (90mm)
jun flywheel,clutch net pp with 4 puck ,3in exhaust,,jwt brain,PAR SYNCRO set,welded case
spearco ,kyb,S3,46mm tial,
