Old 09-06-2003, 12:41 PM   #1 (permalink)
Only Car in Cali W/ Rust!
NX blew up!... need help
So i was at the 1/4 mile track yesterday running 13.3 at 107, and my buddy tells me, you can atleast get a 13.1, just turn up the boost a hair. So, regretfully, i turn the boost up, and when i take it down the track the boost hits as high as 17psi, when i shift into 3rd, BOOM, smoke started pouring out of my exhaust and my car was really choppy. I drive it to where i can park it, (its somewhat drivable, not for distance), pop the hood and there's oil all over my engine bay. It seems to me it came from the dipstick?? it all shot over the hood and stuff with extreme pressure. The engine still starts, but definaly not drivable, what do you think i did? and is it worth fixing? I have an idea of what happened, but i want to know what you all think.
~Zack
My money pit: 1993 Nissan NX with... U13BB det, 2.5in dp, 3in catback, Hotshot FMIC, Blitz Supersound Bov, Z32 maf, S-afc tuned, 16in wheels w/ toyo proxzes, Eibach prokits, Kyb Agx, UR Crank Pulley, Prothane Mounts...
The NX is offline   Reply With Quote
Old 09-06-2003, 12:51 PM   #2 (permalink)
Jah Rastafari
Trader Rating: 55 (100%)
Do you have a fuel ump in the car.
From the info that you have listed up top you need a new long block.
Old 09-06-2003, 12:53 PM   #3 (permalink)
fuel ump? or fuel pump? what do you mean by that? what do you think is wrong with it?
Old 09-06-2003, 01:04 PM   #4 (permalink)
myprojectB13's Avatar
Trader Rating: 16 (100%)
I think he meant do you have an upgraded fuel pump in the car, because its not in your signature. No fuel pump and 17psi = BOOM. Sorry to hear that.
Jonathon
1996 G20
1993 SE-R 13.66@101
Old 09-06-2003, 01:22 PM   #5 (permalink)
nope, stock fuel pump, with 370 inj... damn.. time for engine rebuild i guess.. but what happened? broken rod? hole in piston?
Old 09-06-2003, 03:06 PM   #6 (permalink)
ive come to the conclusion i think i blew a piston, now what do i do? rebuild the bottom end or get a whole new long block?
Old 09-07-2003, 04:02 AM   #7 (permalink)
not my president
i would get a new engine no telling what damage youve done to the block.....i just got replacemnt engine for my egg i missed 4th at 90 mph and hit second oops
Old 09-07-2003, 10:13 AM   #8 (permalink)
if i rebuild i can get even lower compression pistons, but if i buy a new engine i may think about get an sr20ve and throwing the turbo on it but thats a little pricey...
Old 09-07-2003, 08:47 PM   #9 (permalink)
Professor Dingbat
were you running a 3 bar of 4 bar fuel setup? Most liekly ran waaaay lean and detonation killed the fu*ker
Old 09-07-2003, 11:10 PM   #10 (permalink)
sleeper
17psi and 370cc injectors=BOOM. 17psi and stock fuel pump=BOOM. You were pretty much screwed either way. 370cc at 4bar can't handle 17psi either; or at least I wouldn't! And the stock fuel pump is good for around 10psi. Past that and you're taking risks.
Khiem
'05 Evo
'05 CBR 600RR
Old 09-07-2003, 11:12 PM   #11 (permalink)
Professor Dingbat
And if you're running 17PSI on the stock T25, you were shortening its life too
Old 09-08-2003, 04:12 PM   #12 (permalink)
i wasnt running it long, but it was long enough... it was on stock inj, and stock fuel pump. I'm running on s-afc tuned de ecu. I can tune it to as rich as teh injectors will go. But that wasnt enough, i heard the 13psi is the max the injectors and pump will take it. Oh well i guess i learn from my mistakes, expensive, but im learning the hard way
Old 09-08-2003, 08:46 PM   #13 (permalink)
Remove the head and take some pics...
Nissan Primera 2001 Turbo - Daily
Nissan 240SX RPS13 Turbo - Track drifter
Subaru Legacy H6 2005 AWD - Boxer AWD madness
CarloSR is offline   Reply With Quote
